Apple iPad 32 GB WiFi Tablet PC Logo
A
Anonymous Posted on Aug 16, 2014
How do I close web pages in safari? - Apple iPad 32 GB WiFi Tablet PC
Basil Rolandsen
Level 2:
Habit-Forming:
New Friend:
  • Apple Expert 109 Answers
  • Posted on Aug 18, 2014
Basil Rolandsen
Apple Expert
Level 2:
Habit-Forming:
New Friend:
Answers
109
Questions
0
Helped
16979
Points
136
There is a tab over the web site, and in the left corner a circle with an x in it. Press this symbol, and the web page will close.
On th iPhone you need to press the symbol with two squares in lower right corner to get to the tabbed pages.
I have a iPad Pro and my screen has changed from a full screen to one that us 1/2 full what is my problem
How to Turn Off Split Screen on iPad Split View is enabled by default on the iPad. To utilize the feature, you can drag an app from your dock to the right or left edge of your screen to open the app on a portion of the screen. If you have multiple apps open and want to close one without turning off the Split Screen or Multitasking functions in settings, you can return to a full-screen view of a single app by dragging the edge of the app you want to remove to the edge of the screen.
If, however, by "getting rid of split screen on iPad" you mean turning the feature off completely, that's something you can do in Settings. To turn off split screen on the iPad:
  • Open the Settings app on your iPad.
  • Tap General.
  • Select Multitasking & Dock.
  • Toggle off Allow Multiple Apps.
How to Get Rid of Split Screen in Safari on iPad Using split screen in Safari on iPad was a new multitasking feature for iOS 10 that continues in iOS 12. This allows you to open two separate Safari web pages simultaneously on your iPad. To start, open Safari on the iPad. You can then open a second Safari tab in split screen in one of four ways:
  • Tap and hold a link; select Open in Split View.
  • Tap Command+N on an external hardware keyboard to invoke Split View.
  • Drag a tab from its space to either the left or right side of the screen to open it in split screen.
  • Tap and hold the icon that opens your tabs view in Safari. It looks like two overlapping squares. When you tap and hold, options will pop-up. Select Open Split View.
But what if you want to get rid of split screen in Safari? What if you're done using the two tabs-how do you turn split screen on the iPad off? To close split screen in Safari on your iPad, you can do one of the following things:
  • Drag the tab(s) from one of the screens to the other. Once the last tab has been dragged to the opposite side, Safari will return to full screen, which will turn off split screen.
  • Or, you can tap and hold the tabs icon, which looks like two overlapping squares. Then select Merge All Tabs. This will merge all your Safari tabs back into a single window, which gets rid of split screen.
How to save web sites on ipad
Open safari and go to the website. Tap the icon you use for adding a bookmark. You will need to name the icon and select Add you can find it on one of your pages How to Save Website to iPad Home Screen
1helpful
Keeps blacking out when using Yahoo, Google, Bing, and Yahoo mail
Here's a couple of things to try jackw1066.
  • Close out of Safari by holding down the home button then sliding the small Safari page up until it disappears. Then turn off the device by holding down the sleep/wake button and sliding to power off, leave it off for at least 10 seconds then turn it back on to test.
  • Still not working? Go into Settings > Safari > Adanced > Safari Data > Erase all Safari data. Turn it off and on again like above.
  • If it is still not working, download another browser like Google Chrome and see if those work there.
If you are running an old version of the software like iOS 6 (you can check this under Settings > General > About) or you have an older iPad, it might just be a limitation of the older technology. Those sites are designed to work with up to date technology.
If you are running current software or have a new iPad then you might want to restore the device - Safari is part of the software so it could just be a glitch with the software.
My Asus tablet in Internet Explorer is locked with a message ; Attention Potentai l threat detected. I cannot remove this page or X out of it??
Download an app called Taskmanager. Run/open it and elect to end all running programs. This should close your web browser. Im guessing when you say internet explorer you mean Safari?
How remove item iPad reading list?
Swipe from right to left.
If that doesn't work, close Safari and reboot your iPad.
Double tap tap the home button and then swipe up on the Safari preview screen that you see right above the Safari icon. Swiping up on that screen will close the app.
Hold down on the sleep and home buttons at the same time until the Apple Logo appears on the screen. After the iPad starts up, try again.
How to delete history from iPad
Searches could be easily removed at the safari web browser go to the safari menu and delete all entries
  1. Open Safari if it is not already open.
  2. Choose History > Clear History, and then click Clear
Safari not connected to the server
Sounds like your wifi connection is down. If other pages will load, it's the server hosting this page which is down.
IPad trying to reset safari & empty cache &delete cookies & other site
Instructions to clear this information in Safari in iOS can be found on Apple's website: Safari web settings
These are the instructions from the "Additional Information" section:
To clear your history from Safari, tap Settings > Safari > Clear History.
To clear all cookies from Safari, tap Settings > Safari > Clear Cookies and Data.
To clear other stored information from Safari, tap Advanced > Website Data > Remove All Website Data.
1helpful
2answers
Want to down load Safari
I think you can do that in Apple's website.
Android 4.0 Tablet PC
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
