It doesn't show the boot-up sequence corectly.. It says floppy not recognized, doesn't show the SATA or Cd-Rom.. What should I do? Thanks for any help provided,
If you mean Bios password try this:
Resetting the BIOS PSSWRD, Open the computer case and look inside on the motherboard. Dell has diagrams of this. Locate the Little Jumper. It should have small print if you can read on the mother board indicating PSSWRD CLR. Boot the computer to Setup. Carefully remove jumper, becareful of static, and then once removed hit enter. Shutdown the computer, and restart and enter Setup again F2. The password should be CLR. Turn OFF and PUT Jumper back into place and Turn Back ON. You should be able to access Setup.
If you then boot to setup-check your hard drives and floppy that are seen. You may solve those issues in setup.
If you mean the windows password: boot to F8 safe mode and log
on to the ADMINISTRATOR not your log in that has admin rights.
Disable all passwords and restart.
SOURCE: computer booting problem
Hi, You backup Lithium battery may require replacement. The CMOS/BIOS not remembering you prescribed setting is an indication that though the settings were saved, they were not retained and therefore when booted would display the "F1" "Del" choices. Even if the new DVD writer is configured/attached as Primary Slave, as long as you set it to be the first bootable device, the computer would boot from the DVD first. Again, this is done in the CMOS/BIOS setup (as you have done). But the CMOS/BIOS must execute this if retained in its memory. In some rare instances, even with a new battery, this problem do occur. The issue is no longer the battery but discreet components along the memory B+ line such as a reverse protection diode, surface mounted jumper resistor. Hope this be of some help/idea. Post back how things turn up or should you need additional information. Good luck and kind regards.
SOURCE: BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
SOURCE: Blue Screen c000021a
boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
SOURCE: Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
SOURCE: selected boot device is not available
I had the same issue with my dell dimension 2400. The issue I was having resulted in the connection to the drive was loose. Try taking off the side of the case, find the drives in question and reseating the plugins. My pc was quite a bit older though and i don't know if this will be your solution, but its worth a shot. You can even try installing a different cable and swapping to another power supply plug.
That's where you need to check to get solution to your problem, if not... try these
1. your settings in your bios
2. faulty cable/wire to your media device (hard drive, cd/dvd rom, etc)
3. The cmos battery (which indirectly points to your bios settings)
Hope this helps!
