Question about Lisle Serpentine Belt Tool
How do i install serpattine belt on 07 kia sorento3.8 4 wheel drive
How to change drive belt
You have not provided the year of your motorcycle so here is the directions for a 2006 Harley-Davidson Touring Bike. If you need advice as to how to change a belt on a different model year post again with the model year and ask again. If you need directions on how to remove the rear/replace any or all of the rear wheel or the swing arm or the primary case or the starter or the front or rear drive sprockets or etc etc post another request and if I see it I will respond to it.
2006 TOURING DRIVE BELT REMOVAL AND INSTALLATION
Remove the rear wheel and the rear swingarm and then the primary chain case assembly and then the old belt from the transmission sprocket and then install the new belt on the transmission sprocket and re-install the primary case assembly, the rear swingarm assembly and the rear wheel.
Jul 14, 2014 | Harley Davidson FLHRCI Road King Classic...
How to change the drive belt
One assumes the reference here is to the timing belt running hidden under a cover on the passenger side of the engine and NOT one of the external belts that drive the alternator, AC pump and power steering pump.
The timing belt requires precision installation. Its typically a full day task for an experienced mechanic with air tools. Precision installation first requires precision removal and preparation. To access the timing belt remove the passenger front wheel and the center sections only of the wheel well liner that expose view to side of engine. Then loosen tensioner bolts on external belts and remove external belts from the center main drive sheave. They can hang on the remote drive sheaves if desired. Remove upper and lower external covers from timing belt. Using old cloth, wipe the back-wall of the timing enclosure clean of dust and check for oil or coolant leaks. Find yellow chalk or Yellow lumber marking crayon. Look very carefully with bright light for timing marks on anything that rotates and for corresponding mark. At TDC of cylinder 1 all observable marks should simultaneously align. Cylinder 1 is on the rear engine bank closest to passenger seat. Rotate engine manually with battery disconnected and ignition off until alignment of all marks observed. Only then do you release the tensioner and remove the old timing belt. While the timing belt is removed is an excellent time to replace the cooling water pump. There is no timing mark on the water pump, only on the sheaves that drive the camshafts and on the main drive sheave. Also no timing marks on the idler pulleys.
Once the new belt is installed with everything verified in proper alignment and new water pump installed too, the idler pulleys can be set and spring loaded. Then manually rotate the engine through one complete cycle until all marks aligned again. Check torque on all bolts, then start reassembly of timing belt shield first, then external belts and adjust tensioners. Reinstall center wheel well liner sections and then reinstall the wheel and torque the lug nuts.
Reconnect the battery and start the vehicle. If all properly aligned it will immediately start. If anything improperly aligned, you now have BIG problem and likely permanent engine damage. Alignment of the timing belt rollers and sheaves absolutely critical, one omission and the engine is toast. Do it right and enjoy another 60K miles before you have to change the Kia timing belt yet again.
Mar 11, 2014 | 2004 Kia Sedona
Kia sedona instructions to replace serpintene belt
Hi, Here is the procedure for a 2002 KIA Sedona 2.9, Engine code KJ. I I can not guarantee the followingprocedure is exactly the same as your car.
Warnings and recommendations Unless otherwise advised by the manufacturer, the following procedures are recommended: Always fit a new timing belt after removal Check the tensioner and idler pulleys; renew if necessary Never turn the engine in the direction opposite to that of normal operation Check the belt(s) for cracks, fraying, wear and oil contamination Note: The engine must be cold before timing belt adjustment Note: Avoid bending, torsion or traction General Before disconnecting the battery cable, check the audio system security code kj_t_dba_uk_6.jpg
Always check the timing marks before timing belt removal Removal Disconnect the battery Remove the radiator upper hose Remove the fuel filter unit Note: Do not disconnect the hoses carniv_j3tci_t_dba_uk_3.gif
Remove the bracket Remove the right front wheel Remove the air-conditioning drive belt Remove the ancillary drive belt Remove the ancillary drive belt tensioner Remove the coolant pump pulley Remove the crankshaft pulley Remove the timing cover(s) kj_t_dba_uk_6.jpg
Remove the tensioner Remove the timing belt Check the gearwheels, tensioner and idler pulley(s) for damage and wear Renew if necessary Installation kj_t_dba_uk_6.jpg
Align the marks on the tensioner Tighten the tensioner (23.5 Nm) Rotate the engine 2 rotations by hand kj_t_dba_uk_6.jpg
Check the tensioner Repeat the procedure if required Refit the timing covers Refit the crankshaft pulley (373 - 392 Nm) Refit the coolant pump pulley (17.6 - 28.4 Nm) Fit the ancillary drive belt tensioner Fit the ancillary drive belt Refit the air-conditioning drive belt Refit the front right wheel (88 - 108) kj_t_dba_uk_4.gif
Fit the bracket (36.2 - 53.9 Nm) Refit the engine mount carniv_j3tci_t_dba_uk_3.gif
Refit the fuel filter unit Refit the radiator hose(s) Refill the cooling system Check for leaks Reconnect the battery earth cable Torque settings Tensioner: (23.5 Nm) Timing covers (6.9 - 9.8 Nm) Coolant pump pulley: (17.6 - 28.4 Nm) Special tools Special tools are not required
Jan 06, 2013 | 2004 Kia Sedona
I am putting on a new timing belt,need to know the aligned timing marks for a 2003 kia,rio 1.6l
.6L (VIN 3) & 2.0L Engines
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Engine cover
    • Right-hand front wheel
    • Right-hand wheel well side cover
    • Accessory drive belts
    • Water pump pulley
    • Timing belt upper cover
  3. Turn the crankshaft pulley so cylinder No. 1 is at Top Dead Center (TDC). Align the pulley groove with the timing mark "T" of the timing belt cover.
  4. Remove or disconnect the following:
    • Crankshaft pulley
    • Crankshaft flange
    • Lower timing belt cover
    • Timing belt tensioner
    • Timing belt To install:Align the timing marks of the camshaft and crankshaft sprockets to ensure the No. 1 cylinder is at TDC.Temporarily install the timing belt tensioner.Install the timing belt over the crankshaft sprocket, then inside the idler pulley, over the camshaft sprocket and then inside the timing belt tensioner.Apply tension to the timing belt by turning the tensioner in the clockwise direction so there is no slack in the belt on the tension side.Tighten the tensioner mounting bolts to 20 ft. lbs. (27 Nm).Check the timing belt tension as follows:
    • 1.6L (VIN 3) engine: Push the tension side of the belt in horizontally with a moderate force, the timing belt cog end is approximately 1/2 of the tensioner mounting bolt head radius away from the bolt head center.
    • 2.0L engine: Push the tension side of the belt in horizontally with a moderate force, the timing belt cog end sags approximately 0.16-0.24 inches (4-6 mm).
  1. Turn the crankshaft two turns in the clockwise direction and realign the crankshaft sprocket and camshaft sprocket timing marks.
Oct 23, 2010 | 2003 Kia Rio
Timing belt broke on my kia sportage...
Check solutions for Kia Sportage under heading. Need timing marks and ignition wiring by Brattlehead. The markings I gave him will also work for your 2001 Sportage
Dec 27, 2009 | 2001 Kia Sportage
Need to replace serpintine belt need diagram for 07 kia optima
look in engine compartment, there should be a diagram
Sep 13, 2009 | 2007 Kia Optima
1999 kia sportage timing marks
dfd3ea1.gif Crankshaft match marks
Align marks on timing belt pulley and pump body.
Camshaft pulley alignment marks
  1. Align marks on camshaft pulleys with alignment marks on seal plate.
  2. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  3. Loosen tensioner lock bolt.
  4. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  5. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  6. Apply a force of 22 lbs to timing belt between camshaft sprockets.
  7. Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
  8. NOTE: Replace tensioner spring if timing belt deflection is excessive.
Timing Belt Installation
  1. Install lower timing belt cover.
  2. Install upper timing belt cover.
  3. Install power steering drive belt and adjust belt tension.
  4. Install fan pulley.
  5. Install generator drive belt and adjust belt tension.
  6. Install A/C drive belt and adjust belt tension.
  7. Install splash guard.
  8. Install fan and fan shroud.
  9. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  10. Install fan shroud mounting bolts.
  11. Install fresh air duct.
  12. Connect hose to resonance chamber.
  13. Connect battery negative cable.
Jul 26, 2009 | 1999 Kia Sportage
Need a belt diagram for 07 Kia Optima 2.4L
Please dont tell me that Kia forgot to put the Belt diagram sticker under the hood! If so, you may get the info from auto zone or from the Kia dealer. Happy Trails.
May 30, 2009 | 2007 Kia Optima
Lisle Serpentine Belt Tool Logo
185 people viewed this question
Top Lisle Hammering Experts
Robert Wooley
Robert Wooley
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
