Question about Fuji FinePix Cameras
Flash is broken - FinePix Fuji Cameras
Nikon D40x camera flash faulty
Depending on exactly which piece is broken, you can order the flash top cover and/or the flash head assembly.
Dec 24, 2011 | Nikon D40x Digital Camera
The flash will not open.
The spring has broken off from the rear of the pop-up flash assembly. it is broken.
You will need a replacement pop-up flash, a new camera or an external flash unit.
Nov 21, 2010 | Kodak EasyShare DX7590 Digital Camera
I have a Di622 Nissin Flash, the base is broken. The part that slides into the hot-shoe. Would like a quote on the fix.
i have a Di622 Nissin Flash, the base (hotshoe contact piece that slides in camera) is broke is there anywhere I can order the replacement piece?
Jul 20, 2010 | Nissin Speedlite Di622 TTL Flash for Canon
I dropped my flash, bulb broken
if it is charging OK,discharging is failed,discharging components must be replced,xenon tubr etc,contat camera tec.
Mar 07, 2010 | Nikon Speedlight SB-600 TTL Flash
D40 flash latch broken
it seems that the plastic latch which holds the flash unit down is broken. as this plastic part is not available seperatly the camera shop must be changing the complete top assembly, and thatswhy is quoting that ammount
Mar 20, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Broken Flash Bulb Sony Cyber-shot DSC-P93A Digital Camera
Hey, Matt here. You could try getting a cheap broken one off ebay or something. It is unusual for the flash to be the first thing to go so if you got a broken one from ebay the chances are the flash bulb would be good to use. Hope this helps. Matt. Please rate me
Dec 31, 2008 | Sony Cyber-Shot DSC-T33 Digital Camera
Sunpack 544 flash
There can be more than one reasons for that.
1. Broken wire at sync terminal.
2. Electronic sync issue:
2.1. Faulty sync thyristor (CR02).
2.2. Faulty trigger transformer
2.3. Any other passive component around the previous two.
3. Broken sync lead to the flash tube.
4. Broken leads to the main terminals of the flash tube.
5. Electronic fault at main thyristor.
5.1.Faulty main thyristor.
6. Faulty flash tube.
7. Other, like crack on the PCB.
Good luck! :)
If you happen to decide to part with your faulty flash, please consider to write me first, I offer it a good home... best regards, Laszlo klaci(at)index(dot)hu
Mar 21, 2008 | Sunpak Auto 544 Flash
Broken Built-in Diffuser Plate
I can repair your flash for you if you want it fixed
Berrie Smith Camera Repair
bbmw@bellsouth.net
They is six parts to fix the broken piece.
Diffuser two posts and springs, one flip spring
Nov 06, 2007 | Nikon Speedlight SB-800 TTL Flash
Metz 58 - broken
Take out batteries
Put in 4 new Energizer Lit. Bat in.
Turn on flash
Wait for the ready ready, fully charged
Press the test button out.
Flash should be able to be fired.
atdlee@netzero.com
Aug 13, 2007 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Cameras Logo
29 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
