Apple iPad 32 GB WiFi Tablet PC Logo
A
Anonymous Posted on Aug 16, 2014
Reset apple id account
Can't log in to ipad, i forgot my apple id password
I Know A Guy Computer Services
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Aug 17, 2014
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
4491
Points
52
Unfortunately, you will need to get to a laptop or tower PC or Mac, in order to reset your password, migrate to apple.com try to login, there should be a forgot password link just below the login entry points. The Mobile version of Apples website malfunctions when attempting to reset a password, this is why you need to go through a laptop or tower to have a successful password reset.
3 Related Answers
Jim Thomson
  • 1099 Answers
  • Posted on Feb 06, 2012
SOURCE: how to creat Apple ID for Ipade 2 16 gb
Go to https://appleid.apple.com/cgi-bin/WebObjects/MyAppleId.woa/
A
Anonymous
  • Posted on Apr 03, 2013
SOURCE: Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
A
Anonymous
  • Posted on May 02, 2013
SOURCE: How do I access my myspace account if I forgot password & security questions?
You can reset your password using your email account by visiting: https://www.myspace.com/auth/resetpassword/
Hope that helps!
How do I unlock my ipad activation lock without i-tunes. I forgot my password and apple I'd.
If you bought a second-hand iPhone/iPad stuck on the activation lock screen and don't know the previously used Apple ID and password, iMyFone iBypasser can help you activate iPhone/iPad without Apple ID. This excellent tool came out in 2020 and has helped many users who reset their own iPads without logging out the previously used Apple ID.
I need recovery my passwordmaiCloud mail for iPad
Hi Jaime.
not sure if this will help you out.
On your Mac
  1. Go to Apple menu > System Preferences, then click iCloud.
  2. Choose Account Details.
  3. If you're asked to enter your Apple ID password, click "Forgot Apple ID or password" and follow the onscreen instructions. You can skip the final steps below.
  4. Click Security > Reset Password.
If you forgot your Apple ID password - Apple Support
https://support.apple.com/en-gb/HT201487
2answers
How do I set up an apple id account on a used ipad that was given to me?
Reset iPad to factory settings: go to "settings", at the bottom of screen click on "Reset." You will have to re- initialize the iPad as a new device with a new "Apple I.D.
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
How do I reset my Apple ID and password on my apple iPad Air without boot disc or iCloud password
Follow these steps to reset your forgotten Apple ID password: https://support.apple.com/zh-cn/HT5787
I have two iPads & my Twitter account works on one but not the other. When I log it, I'm told Password is wrong. I've changed password twice but it is never accepted on the 2nd iPad. Can you help?
You can use forgot password option in the IPad where your twitter account is not working properly.
Then reset your password and login to twitter using the same IPad which was having problem.
Getting started with Twitter for iPad
The last section of this link provides you with information on resetting your password.
If in case the problem persists then it must be an Apple problem.
Don't remember password for ipad
You don't need to know your password for the iPad. As long as you know the password for your iTunes account, you used to setup the account on the iPad for. Connect the iPad with the computer and open iTunes and give in the password for the iTunes account. Apple will unlock the iPad and you can setup a new pass code for the iPad.
When you forgot your iTunes password, you have to contact Apple and prove you are the legal owner of the account.
Use this link to find more support for that:
Apple ID Support
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
