Question about Jura Capresso Impressa S7 Coffee Maker, Espresso Machine
Jura S7 says fill tank but tank full
Machine was unused for couple of months. Now after warming up trying to brew it makes normal (although labored) noises but no coffee comes out. The display then says "Fill Tank" but there is water in the tank. The dry coffee grounds are disposed in the grounds container. The steam and the hot water on demand works normal with steam and hot water coming out.
    President:
  • 1,618 Answers
The brew unit is damaged and needs to be repaired.
Posted on Sep 12, 2014
Anonymous
SOURCE:
Anonymous
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
Morten Bergendahl
  • 60 Answers
SOURCE: Jura S9 Capresso Machine "Fill System" Message
I think you use too fine grist on the grinder, or the coffeebeans are really dark and moisty. Try to set the grinder to a coarser grist, for dark roasted coffee it`s not recomended to to use any finer than medium grist. However, the sieve in the brewing unit could be clogged, and you need to clean this out. Put a finger up in the brew unit just along the grounds blade, you will probably find a lot of old fine coffeeground up the. Clean it up as best as possible, and then try to make coffee with coarser grist. If this helps, it`s smart to run a cleaning program to be on the safe side.
If nothing of this helps, you don`t have a choice, you have to send it for service, then the brew unit has to be dissasembled and cleaned from the inside.
Posted on Jun 02, 2009
KenMacBoston
Ken Macumber
  • 12 Answers
SOURCE: Jura S9 coffee machine not drawing water - says FILL SYSTEM
Try using the "shipping" unit button to shut everything off. Turn off the unit and then tryo to run it again.
Posted on Sep 20, 2009
Tushar
  • 9 Answers
SOURCE: Changed Claris Filter-now says
Fill your water tank with Warm Water and then try a few times. Keep Patient and Keep trying for some times and it will work.
Posted on Oct 16, 2009
Bob Keast
SOURCE: My Jura Capresso Impressa E8 is leaking water
I have the same problem with my E9 and I have traced it to the diaphragm unit that is just distal to the pump itself. Apparently, the diaphragm is secured with a steel band (not stainless since it is rusty) that may hold seals or O-rings that break down. You can observe it leaking when pressure applied during brewing. The question is: can a new unit be ordered and if so, where?
Posted on Nov 05, 2011
My Jura Ena 5 is stuck in a open tap request. It will not brew or rinse.
TRY SWITCHING IT OFF AND RETRY LATER MAY BE IT WILL RESET IF NOT CHECK FOR ERROR OR TELL US MORE ABOUT THE FOULT
Mar 05, 2016 | Jura Capresso Coffee Makers & Espresso...
Hi, our Jura Impressa Xs90 keeps flashing 'fill system' & ' press steam'. There is plenty of water in it, we've tried removing the water and refilling. Doesn't work. If you press steam it just beeps...
Have you run a decal recently? This normally happens when a small particle (normally) an undesolved piece of the decal tablet is stuck in the flow meter, or sensor.
You can try and run warm water through the system and after about half a tank it should be sorted out.
May 02, 2011 | Jura Capresso Impressa X90 Espresso...
I have a s7 Jura capresso expresso machine. It has been packed away for a year and followed the instruction as it was it was my 1st time (7 section 7 of the manual). I have filled it with water as per...
First, I'm not JURA technician. But I have worked on similar table top "Super Automatics" You should call your vendor or the MFR for service. Especially if it's still under warranty. There are no customer serviceable parts in this machine.
*** the following is for information only ***
- Water not getting to machine or not sensing that the water tank is already filled.
* There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up).
* Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement.
* Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
PS: I've noted this tank also uses a water filter (which is probably dry after sitting around for a year as you mentioned.) you will probably have to flush out the air in the filter prior to this unit's pump to work properly. I found a youtube vid that may help:
https://www.bing.com/videos/search?q=s7+Jura+capresso+expresso+not+filling&&view=detail&mid=FA80FAE0243927C50056FA80FAE0243927C50056&&FORM=VRDGAR
Feb 11, 2018 | Jura Capresso Impressa S7 Coffee Maker,...
The S9 has been unused for three months and I cannot get it to get water to the brewer. It keeps telling me to fill the water and press the steam button. No such luck. Is there a way to prime this machine?
Hello
This is a common problem and there`s usually only 1 thing you can try to do yourself. Use luke warm water in the watertank and repeat the fill system procedure 4-5 times. If this doesn`t help, try to shut down the machine and try the same after 30 minutes. If nothing happens after you tried this a few times, then theres a problem with the solenoid valve for steam, and this need to be changed. That`s something you need help from a technician for.
Jun 13, 2010 | Jura Capresso Impressa S9 Coffee...
My Jura Impressa xs90 keeps stating fill system, even after filling the system several times for the last 3 days.
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
Oct 15, 2009 | Jura Capresso Impressa S9 Coffee...
I have a Jura S9A that is about 2 years old, brewed about 1600 cups. Regular filter changes/cleanings. When I brew a coffee, it dribbles out, but makes a full cup of coffee. It also has trouble getting a...
It's all plugged with 'lime scale'. That's the white stuff that builds up from hard water. Regular vinegar run through at least two cycles will clear it, then a couple with fresh water to rinse it. That will bring it back to normal flow!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 10, 2009 | Jura Capresso Impressa S9 Coffee...
I have a jura capresso S7. I am finding water in
This is normal, after each cycle the brew unit will empty the drainvalve for excess water, this will ensure that the water used for each new cup is fresh from the watertank.
Jul 14, 2009 | Jura Capresso Impressa S90 Espresso...
May 31, 2009 | Jura Capresso Impressa S9 Coffee...
"Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Jan 28, 2008 | Jura Capresso Impressa S90 Espresso...
Jura Capresso Impressa S7 Coffee Maker, Espresso Machine Logo
625 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
