SOURCE: how install internet explore in samsung galaxy tab
Download internet explorer software i.e. mozilla Firefox or google chrome from other PC. Save file to flash disk, connect flash disk to your Tab, install the software > Done.
SOURCE: How do i install java for the samsung galaxy tab
Even though Android is based on Java, you cannot just pop in a .jar file and play it. It needs to be in apk format, short for android package(i presume). You need to first transfer the file to your sd card and use a file manager to find it. then click + install. I suggest ASTRO (file manager)
SOURCE: just installed an external memory on my Samsung Galaxy tab 2, 7 how to start using it
First make sure it is ready and formatted. Then treat like any other drive.
SOURCE: My samsung galaxy tab is frozen. I cant even shut
By holding the power button down for about 10 seconds it rebooted
Note: These steps clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Upuntil the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. PressHome to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
