Samsung Galaxy Siii Gt-i9300 16gb Marble White Factory Unlocked Gsm I9300 S3 3g Hsdpa 850/900/1900/2100 Logo
M
Magdalena Lazos Posted on Aug 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why won't my phone recharge after 3 hours?
The red light is on but instead of charging it goes down
Rani wadia
Level 3:
Master:
  • Samsung Master 996 Answers
  • Posted on Dec 22, 2014
Rani wadia
Samsung Master
Level 3:
Master:
Answers
996
Questions
5
Helped
416792
Points
2461
Does the red light turn green when the retro Coleman 5312 is fully charged?
Read page 3 of the manual.
The red light is on when charging, it does not change colour but goes off when not charging. It will take up to 18 hours to charge for 9 hours of use on low.
12V Lead acid battery should be kept charged all the time, even when in storage.
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Try another USB charger - any will do, although it's probably the battery that is at fault.
1helpful
My battery died on the Nokia 6790 Ive been charging the phone for over 3 hours and only the keyboard lights up when i hold the "on" button but the screen doesnt turn on
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
How long does it take to charge the battery
Usually 2 to 3 hours BUT
FS240BX battery how Long should it take to charge.
Hi .Charge the battery initially for 9 hours.
After the initial charge, under normal usage, your power pack should be fully charged in 3 to 6 hours. If the power pack is run-down completely, it may take up to 6 hours to become fully charged.
The red light is just a power indicator. The light will not go out, change color, or blink when the charging has been completed.
To prolong power pack life, avoid leaving the power pack on charge for extended periods of time (over 30 days without use). Although overcharging is not a safety concern, it can significantly reduce overall power pack life.
The power pack will reach optimum performance after being cycled 5 times during normal usage.
There is no need to run the batteries down completely before recharging. Normal usage is the best method of discharging and recharging the batteries
Hope this was of some help to you.
1helpful
My HTC smartphone wont turn on or charge and when I plug it in it shows a red light instead of an orange one. Do you know why?
Have you tried leaving it to charge (with the red light on) for a few hours. The red light usually means a completely drained battery that needs a few minutes/hours to recharge.
Also, try cleaning the battery connectors with a rough toothbrush...
Indicating steady red light can not charge
Rub the terminals of the battery with your fingers and than again put it on charging .... before doing that remove the battery from the cell for an hour..
American Telecom cordless answering machine w/3 ext. #RA2184BB
You more than likely have one or both batteries DOA. Switch them out with OTC rechargeables.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
