The light inside the drum comes on when the door is open but nothing come on when I press the select buttons.
Most likely you tripped the over heat fuse.
This will happen if your vent hose is clogged or worse inside the machine's plumbing from filter to vent hose.
Look up the electrical diagram and figure out where it is, yours should be in the back of the machine but verofy.
Get a Digital Volt Meter at Harbor Freight $5.00 and measure the OHMs on the fuse, if it fails then you need to replace it but first make sure vent is clear or it will trip again.
Fuse is there to keep from over heating and a fire hazard.
Post your findings,
Jim
SOURCE: Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
SOURCE: kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
SOURCE: My kenmore 400 series dryer
There is a thermocouple on the inside that prevents the dryer from getting too hot. If this burns out this opens the circuit so the dryer will not work but all other functions will work.
SOURCE: Kenmore Elite Smartheat Quiet Pak 9 won't start.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
