Whirlpool Duet GHW9150P Front Load Washer Logo
A
Anonymous Posted on Aug 19, 2014
Started a load interuppted it now won't turn on and door is locked
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
Machine turns on but won't start
this means that the door is not shut check to make sure the door button is still there its behind the door on the frame you should see a little black button sticking out if its not there you need a new door switch if its there try pushing the door button a couple times really fast sometimes this button gets stuck if that doesnt work its probably your door lock
Kenmore HE2 Won't Turn On
1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
I have an LG WM2701H. It's about 2 years old. I did one load of laundry this morning, everything was fine. I started the second load, walked away and after a few minutes noticed that the washing...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Door lock
Check for loose wires in the door lock; or replace door lock.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
