Need instructions to replace transmission on mav5000aww maytag washing machine. Online search did not help.
SOURCE: Maytag Neptune Lid Lock Replacement
I have replaced my right lid lock twice and the second one just went bad. The left one does not matter, only the right one tells the washer the lid is locked. I think the bleach cup is the problem, bleach corodes the metal contacts in the lock. Try removing the plug and cleaning the contacts. I am going to bypass this lock I am not buying any more parts for this unit!
People have reported replacing this lock several times in unser two years.
SOURCE: Maytag Mav5000aww having pump problems
www.applianceaid.com/norgewash.html gave us the info on popping the lid to access the screws for removing the front panel. Piece of cake from there...
Thanks for asking. Other promises of help followed up with password requirements and requests for dues to join their super-seeker club.
SOURCE: How to replace a belt on a Maytag MAV6000 washing machine
hey good for you thats an eazy one .pull the washer out abit and then tip so the top resting on wall behind.be careful dose not slip out from under but ihave done it a hundred times as a repairman.before replacing the belt inspect the motor pulley,its plastic and they do melt.also inspect the pump pulley making sure it turns freely and the spot welds are not broken joinning the pulley to the pump shaft...........other wise just spin the old belt off and spin the new belt on.the belt goes on a total of three pulleys .thats it if you need any other help you can email . God bless ,tom
SOURCE: Steps to disassemble Maytag washer's transmission mod LAT9704AAE
I had an outside service tech. to repair it . He replaced seals and bearings .
