Will not turn on
Following information is not mine but from another site. This is a cut and paste since i didn't want to give you the bad news. Now the news;
I e-mailed Canon tech support, and received a suggestion to remove, wait for 20 minutes, then reinstall the batteries. I confirmed that they were fully charged, and restarted the camera. The lens extended, but the LCD display is sometimes shot through with horizontal lines resembling static, which are recorded in photos taken afterwards (examples attached.). The camera now starts up randomly, and the lines come and go randomly. The only offer Canon has made after this was to offer an "upgrade" to a refurbished S2 IS for $299. That's about the price of a new one online! I have decided not to buy any Canon digital camera again. I would, however, like to try to get this one running with a degree of reliability.
Canon S1 won turn on E16 error HELP Canon Digital Photography Forums
This is all the info i found. Hope this helps. also sorry about the camera.
SOURCE: error code
I found the answer on another site and was able to fix my camera myself. E24 means your LCD display has come unplugged. What happens if you rotate the screen too much you tighten up the wire and it pulls the connection out of its socket. There ar 4 screws on hedispla, unscrew ad take th back off the screen. Unwind the screen until the wires loosen up. Replug in the loose connector. Resecure the back
I appreciate your post, Deejanae!
I see that your Frigidaire dryer is displaying an error code of "E16". It appears that "E16" is an invalid code. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to experience an issue with an "E16" error code I would recommend contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
