How to reset the right and left margins on the typewriter and to keep it in the normal print mode at all times?
SOURCE: margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
SOURCE: Nakajima AE-830
The typewriter is set in P.S. mode instead of 10 or 12. This switch is in lower left corner of keyboard.
SOURCE: How do I release the left margin on a Nakajima
Go to the L. mar, press but don't hold mar rel key, space or backspace to desired location, press L. or R. mar key.
DickyO
