Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
A
Anonymous Posted on Aug 19, 2014
How do i get caption only on mute - Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
bubbab
Level 1:
Habit-Forming:
  • Contributor 18 Answers
  • Posted on Aug 23, 2014
bubbab
Contributor
Level 1:
Habit-Forming:
Answers
18
Questions
0
Helped
5341
Points
33
On newer Sony TVs you press the CC button to cycle through the available settings for Closed Captions (CC): On, Off, and On when
Muting.
However, it looks like your factory remote control lacks a CC button and your TV menu appears to have a simple Off/On option for what Sony calls Caption Vision. If that is the case then you would need to manually turn on Caption Vision when you mute the television. That hardly seems like the solution you're after.
If you had an aftermarket remote control that could record macros you might be able to program it so that when you press the mute button the TV would mute and also turn on Closed Captioning. This would require the proper remote control and some expertise.
How do you remove closed captioning? I have a 4yr old 50" plasma tv. Today the captioning just popped up and I can't figure out how to get rid of it
Hi
1* Use the CAPTION button repeatedly to select Caption Off, EZ Mute, or On.
* EZ Mute shows the selected captions option (if available on program) when the TV sound is muted.
2* Press the ENTER button to save.
Caption Tips
* Not all TV broadcasts include closed caption signals.
* Sometimes TV stations broadcast four different caption signals
on the same channel. By selecting CC 1 to CC 2, you
can choose which signal you view. CC 1 is usually the signal
with the captions, while Another mode might show demonstration
or programming information.
* Your TV might not receive caption signals normally in the following
situations.
OK.
Black square comes on tv
hi,
in your tv the closed caption option is in on position. make it off o run out the black square.
to make the closed caption (cc) off. do the following.
1. press the menu button
2. select setup
3 go to closed caption (cc)
4. select closed caption mute (cc mute)
ok
2answers
How do you get closed caption on
manual below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man Turning On Captions Pressing the CC button displays caption options: ? CC on: Displays captions. ? CC off: Turns off captions. ? CC mute: Displays captions when the Mute button is pressed. To assign your preferences for captions, see “Using the Closed Caption Menu” on page 33.
Closed caption problems
Most sets do not automatically go CC when Mute is pressed--it's a feature on some. They are either on or off and the systems are different for old SD (white on black) and for new digital and HD (control colors, font, and size). I wouldn't want a mute indicator and CC but I do have CC on all the time--yellow on transparent. The NTSC-analog had the captions encoded on a video line (21 22 or 23?). ATSC does not have those wasted off-picture lines and sends it separately. -Ken
I need help with removing captions
This information was found on the Magnavox website http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&grp=TV_GR&session=20090602222010_68.190.209.25&ctn=27MS343S&mid=Link_UserManuals&hlt=Link_UserManuals in the owners manual on page 20. If this information does not solve your problem. Try calling Magnavox customer support at this telephone number 1-800-705-2000. Give them the model number of your television and tell them about the problem you are having with not being able to turn of the closed caption feature. I hope this helps you solve your problem. 1Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL- to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE). CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL- to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Closed captions stopped working
Is this on everything you watch? Not all shows or broadcasts have closed caption.
Does it work when you mute volume? Closed caption can be set to only come up when volume is muted. If so, check settings in menus.
Closed Captioning comes on every time i turn on the tv!
Apparently the 2002 Sharp model TV that I purchased has the closed captioning by default if the mute button is engaged. So there is no solution for my particular model, it has been built in this way. The only solution is not to use the mute button and lower the volume instead.
1helpful
Closed caption
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
to display the
CC-2, or CC-MUTE).
CC-MUTE sets
restore the sound.
to confirm your
selection.
menu.
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
