Plsss help me to fix broken my sansa e250 usb port....plzzzzzzzzz
SOURCE: There is no FM radio option in my Sansa e250 mp3 player
Go on the Sandisk Website and download the firmware updater in the support and let it run and update your firmware and it should solve it.
Thank you and please respond with any comments or more questions.
-John-
SOURCE: i have a problem with my sansa e250
Volume + while connecting to computer will send Windows into recovery mode
SOURCE: Sansa E250 won't turn on
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
SOURCE: Sansa Fuze won't charge from laptop.
Have you downloaded the latest drivers? Have you gone into control panel and device manager, and make sure the device is enabled and allowed through your firewall? Do you have the software downloaded for it?
You can also go to my computer, and find sansa drive folder which you can go to and check the properties to make sure device is NOT set to read or write only.
