Question about Lisle Serpentine Belt Tool
How to route 1996 tahoe serpetine belt - Lisle Serpentine Belt Tool
2 Suggested Answers
6ya staff
SOURCE:
rwooley
Robert Wooley
  • 177 Answers
SOURCE: routing for serpetine belt 99 olds intrigue 3.5
TRY THIS SITE, IT HAS THEM ALL.
http://www.daycoproducts.com/daycoweb.nsf/cf652a4feb630ad0862571a4005ae40c/a866a821123f887c862571a5006988df!OpenDocument
Posted on Jan 02, 2010
Ford 2000 windstar install multi-v belt 3.0 AC
2000 Ford Windstar 3.8L Serpetine Belt Routing
I have seen several posts here about belt routing. Many provide descriptions of the routing but, I didn't see a picture. Pictures help greatly... here's one for 2000 3.8L Windstars.
Jan 19, 2011 | 2000 Ford Windstar
Need diagram to replace serpetine belt on 1995
should be on the underside of your hoos or on your rad support
Jan 29, 2010 | 1995 Dodge Spirit
Diagram for installing serpetine belt 1987 ford 4.9 liter
Belt removal instructions (and routing information) may be found on a sticker under the hood. I have posted a picture of the diagram below if these instructions have faded. The routing on the left is without the AC.
Nov 10, 2009 | 1987 Ford F 250
Serpetine belt install for 2001 mustang
you can also use a 3/8" breaker bar on the belt tensioner.
make a sketch on how the belt is routed before you remove.
Nov 03, 2009 | Lisle Serpentine Belt Tool
1996 Cherokee serpentine belt no moving.
Sounds like you have something locked up.
Take a picture/draw a diagram of serpetine belt routing.
Remove the belt, then try turning each individual item the belt powers to see which one is locked up.
I'd start with the AC Compressor first, then alternator, the belt tensioner, power steering pump, and whatever else is powered by the belt.
Sep 24, 2009 | 1996 Jeep Cherokee Country
Need diagram how to install serpetine belt for my 1997 pontiac
CLICK HERE - as you did not indicate the accessories installed.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 27, 2009 | 1997 Pontiac Bonneville
I replaced the "water pump", i need to know the serpetine belt route and how to install the new belt
Go to this website : autorepair.about.com/library/images/b1869a-lib.htm Theres your belt route. After that belt is run put a I believe it's a 5/8ths or 9/16ths socket on the tension pulley. Pull down on it and you should be good to go............Thank you for using Fixya.com..........Please rate this solution...thank you!
May 15, 2009 | 1996 Buick Park Avenue
What is the serpetine belt routing for a 97 chevy tahoe 5.7 ?
looking down onto engine feed belt down to your left around crank pulley, route up putting back side of belt around w/pump then continue rest of belt around outside of remanning acc. leaving top idler last. put 3/8 drive ratchet into tensioner and rotate down slipping belt over idler
Dec 21, 2008 | 2004 Chevrolet Tahoe
Surpintine belt diagram
Two places of information. One is under the hood, usually form on the engine. A small white diagram that will show the proper routing for the serptine belt.
Second. Purchase a auto repair manuel at the parts store and it will show the routing the serpetine belt. If you do not have the correct routing you will never get the belt on.
Bill
Oct 24, 2008 | 1992 Buick LeSabre
Lisle Serpentine Belt Tool Logo
182 people viewed this question
Top Lisle Hammering Experts
Robert Wooley
Robert Wooley
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
