1)Make sure the tablet is NOT connected to the charger 2) Power off the tablet by holding down the power button for about 10 seconds 3) Once it is off, hold down the HOME button and connect the charger while the button's being held down. 4) When you see the HKC logo come up, let go of the HOME button. 5) Eventually, you'll see an Android logo with a red exclamation mark. If you don't, repeat step 3-5. 6) If you do see the Android logo, hold down the POWER and HOME at the same time for one second and just let go of the HOME which should bring up a "Recovery mode" menu with blue letters. Make sure you let go of the POWER button as soon as you see the menu pop up, otherwise your tablet will just shut itself again. 7) Navigate to "wipe data/factory reset" using the HOME button and select with the POWER button. 8) Navigate to "Yes - delete all user data" and select it. 9) Once it's done, you should see the menu come up again. Navigate to "Wipe Cache" and press the POWER button
10) It should take you back to the recovery menu. Simply press the POWER button while highlighted on the "Reboot system now"
This happened to my nieces HKC 7" Tablet and I held the Power button and the Home Button down for about 10 to 15 seconds and it reset everything and is still working to this day
ALL CREDIT OF THIS GOES TO HKC...
this 100% works to factory reset if you are locked out of a hkc p886a tablet...
For and HKC 7" tablet there is no reset button however you can follow these steps to reset it first you power the device off completely next you hold down the power and volume up button simultaneously until the words HKC touch the wonderful world appears then you will release the power button only you will then find an android on its back you may release volume button then you will tap android or press power button to open the menu you use volume keys to scroll and power button to select scroll until you find wipe completely select that
