Dell Inspiron 1525 Notebook Logo
A
Anonymous Posted on Aug 21, 2014
How to cut and paste with a dell labtop
Using the mouse pad on the labtop doesnt bring up the option to cut and paste. How to fix it?
Shira
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 119 Answers
  • Posted on Aug 21, 2014
Shira
Expert
Level 2:
Cheetah:
Night Owl:
Answers
119
Questions
Helped
20547
Points
180
Keyboard shortcuts for cut and paste are:
Ctrl+C=cut
Ctrl +v= paste
These work on every computer I have ever used.
1 Related Answer
Anonymous
  • 21 Answers
  • Posted on Jun 19, 2011
SOURCE: I have a dell xps M1330. Its mouse pad is behaving
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
How do I cut and paste with a lenovo think pad?
In Windows OS, cut & paste is commonly done with a right click of the finger pad as one would use a mouse. There are shortcut key strokes, but this always works and you'll never forget it. Control C and Control P are the short cuts.
1helpful
2answers
My Dell Vostro 1014 laptop's touch pad does not work!! The buttons work fine but I'm having problems with the pad. The drivers are up to date and the application used to control the touchpad c
If you have a external mouse, or you can borrow, go into device manager to see if the pad is enabled, if okay! try a system restore bringing the computer back in time before this happened, if still no luck the sensor pad maybe defective, the last option a complete recovery of the operational system to factory setting, this will prove if the sensor pad is defective, or wire ribbon might have come loose from the motherboard.
2answers
I have a dell xps M1330. Its mouse pad is behaving weird. If I try using it, it doesnt work but if I keep holding a shortcut key(play/stop/volume keys) while using the mouse pad it works fine. Any help?
hi,
good luck
gorbesia
The arrow on the mouse kepts junping around ?
You are probably using a laptop with a touchpad. What is happening is that your thumbs are touching the touch-pad as you type and the cursor is jumping around. Solution: disable your touch pad. You can go to Start > Control Panel > Mouse > Touch Pad > Disable
Another solution is to go to the Dell website > Support and Drivers > download and install the Synaptics Pointing Device driver and disable your touch pad using the options in this new driver.
2answers
As I type the cursor will jump backward whverever it wishes as follows. As I type the cursor will jump backwarderever it wishes as follows wh
This happens for 1 of 2 reasons: 1. Either your wrist hits the mouse pad and that makes the cursor move
2. If your mouse moves all the time without your control you need to have your palm rest replaced
When this works vote me a 10
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
My my touchpad doesnt worrks
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, option here to Disable,
1helpful
My right button on my Dell touch pad isn't working....
The right mouse button might worn out due to normal wear and tear in everyday use. These buttons are usually replaceable bring it to your local Computer Tech. and have it serviced.
How can i fix my dell mouse, the laser eye cuts in and out
Most Probably the Leence have gone Bad and you need to get it replaced asap
go to bust buy and buy a new one with in $15
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
