SOURCE: Leaking washing machine - hotpoint aquarius 1100 - wm63
water leaks are very hard to locate as the water always drips from the bottom, it is just a case of detailed looking, after a while there will be a dry white mark where the water has dried out, this will show where the leak originated from, there are a few things at the front of the machine that it could be, sorry can't help much more nearly all parts can be bought by the public and with common sense and taking very detailed notes where wires came from etc, most jobs can be done by a competent diy person with basic electrical knowledge remember water and electric do not mix always unplug from power supply where working on any appliance
SOURCE: My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
SOURCE: water leaking inside the washing machine
you need to replace the water valve there should be 2 screws in the back bottom corner of your control panel take them out then stand in front grab each side of control and slide foward control and then pick up and lean it back then you will see a 2 clips holding you housing of your washing machine and a plug undo the clips and unplug the wire once done that grab each side of the casing and swivel it foward then slide the bottom front foward now you can access the water valve to replace it please rate
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
