Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
A
Anonymous Posted on Aug 22, 2014
Power surge on ffu2065fw2 , what wil it do - Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
  • Official Brand Answer 2,267 Answers
  • Posted on Aug 26, 2014
Fixya Pro
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289999
Points
2557
Hello friend, thanks for your post!
I see that your Frigidaire freezer had a power surge and you're asking what could happen. If your appliance had a power surge it could cause an issue within the board or wiring harnesses. Is your appliance giving any error code or beeping? If so, could you advise what it currently is doing? I look forward to providing you any assistance. -Matt
Is there a reset on a Holiday chest freezer
Check the thermostat, defrost timer and compressor overload one of them could have been damaged by the surge.
Model 253.28432807. Household power went off today for a couple of hours. Restored. Freezer has power but display is illegible. Up arrow does nothing. Down arrow changes display but display is erratic and...
Electronic components are very sensitive to voltage surges, spikes or sags.
Voltage is not delivered at a constant 120 volts. With alternating current, the voltage rises and falls in a predetermined rhythm. The voltage oscillates from 0 to a peak voltage of 169 volts. Most appliances and electronics used in the United States are designed to be powered by this form of generated electricity.
During a power surge, the voltage exceeds the peak voltage of 169 volts.
A spike in voltage can be harmful to appliances and electrical devices in your home. An increase in voltage above an appliance's normal operating voltage can cause an arc of electrical current within the appliance. The heat generated in the arc causes damage to the electronic circuit boards and other electrical components.
(Smaller, repeated power surges may slowly damage your electronic equipment, over time too.)
Voltage sags, a.k.a voltage dips or brownouts, is another form of electrical disturbance that can damage appliances as well.
The bottom line, power surges, spikes, and sags can vary in duration and magnitude; and can damage electrical equipment ranging from stereos to computers to any household appliance that uses chip board circuitry sensitive enough to "blow" due to over or under-energizing it.
110v surge protector that conserves power for freezer
A surge protector for a freezer is a good idea. To conserve energy? On paper it looks good but seriously only real savings are on bigger equipment.
Temperature adjust frigidaire ffu2065fw2
Hello Ron Thacker - Often when the temperature is too cold, it is because the temperature control is set too cold/high. Turn the control to a warmer setting and allow several hours for the temperature to stabilize. If the unit does not stabilize within 24 hours, then it could possibly have a faulty thermostat or temperature control. I would personally reach out to an experienced tech that will be able to identify the precise reason.
Emerson 2.8 Cu. Ft. doesn't automatically turn on after power outage
Check breaker. Was there a surge of electricity when the power went out. This may be a simple fix. Sounds like the breaker is tripped. Test the outlet with a light to see that power is to it.
Is it safe to plug a typical Kenmore kitchen refrigerator/freezer into a surge protector?
Safety is not an issue, the problem you may have, depending on the surge protector, is that when the compressor starts up the amps drawn from the circuit is very high which could cause the surge protector to trip, then the power would be shut off to the refrigerator,NOT A GOOD THING!
Good luck !
7helpful
Freezer door left open
Your fridge should be fine, if you have surges that frequently getting a whole house surge protection package would make alot of sense. Surges are especially damaging to electronic circuits found in TV's computers, cell phones, answering machines aell frankly in just about everything. Well worth the charge.
May 22, 2009 • Freezers
2helpful
Frigidaire Freeze FFU1764FW0 failed after power brown out.
Yes a power brown out can cause compressor failure. More than likely If there was a power surge it is possible that the overload on the compressor opened. This is a safty device that helps protect the compressor. It usually resets itself but in the cause of a surge it may have burnt up. problem could also be in the relay or thermostat
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
1helpful
Kenmore upright - wont defrost, runs continuously and wont freeze properly
well don't be surprised, these electronic fridges run on dc electronics also and are sensitive to power surges. is this the freezer because there's no thermostats just the limit control. use a surge protector on the outlet to protect the electronics. if your still having problems get the limit sensors changed first (if applicable). if you want to go the safe way, I'd consider buying a surge protector and connecting it to the power.you can e-mail me with any questions @ [email protected]
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
