Also how do you clear a wireless door sensor tamper alarm?
SOURCE: Sensor alarm notice on GE Simon 3 system
Most likely it is remembering a alarm at that station. If you enter your alarm code following the "status", it will clear it. (That's how mine works)
SOURCE: battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
SOURCE: sensor failure Simon 3 wireless home alarm
the sensor is going out, i would switch it out with another one in your house and see if the problem follows it there.
SOURCE: How can I disconnect the motion sensor from the GE
Your wireless motion detector has been "learned" or programmed into your system. It may be difficult to remove it without a knowledge of how to de-program and you'll also need an installation program manual. A much simpler alternative is to mask off the lens portion of the motion detector. If you are able to open the case cut a small piece of cardboard or heavy stock art paper and place it in between the motion's circuit board and the lens assembly. Once reassembled this will block the detector from seeing motion. If you can't figure out how to open the case another way is to take a piece of cardboard and tape it over the lens face on the outside. Hope this helps.
