Home Security Logo
s
steve matherly Posted on Aug 22, 2014
Why does my lorex dvr keep peeping - Home Security
David Schneider
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Sep 10, 2014
David Schneider
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
19362
Points
36
Because the units are garbage
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Jul 31, 2009
SOURCE: cant access lorex DVR from the internet
i have the same trouble, and i did what u said and it doesn`t work yet:S something else????
Lorex LHV1000 HD DVR. I have one that does not want to boot. Power turns on, fan is working, but HDD light doesn't blink and nothing is coming on the screen. Power button doesn't seem to work.
If your Lorex LHV1000 HD DVR is not booting up, there are a few things you can try:
  1. Check all cables and connections: Ensure that all cables are securely connected to the DVR and that there are no loose connections or damaged cables.
  2. Restart the DVR: Disconnect the power cable from the DVR, wait for a few minutes, and then reconnect it. Try to power on the DVR again.
  3. Reset the DVR: If restarting the DVR doesn't work, try resetting it to its default settings. This can be done by pressing and holding the reset button on the back of the DVR for about 10 seconds.
  4. Check the hard drive: If the DVR is still not booting up, it could be due to a faulty hard drive. Try removing the hard drive and connecting it to a computer to check if it's still functioning properly.
If none of these steps resolve the issue, it may be necessary to contact Lorex technical support for further assistance.
My lorex DVR won't turn on
If your Lorex DVR won't turn on, it is likely that the power cord is not properly connected. Make sure that the power cord is securely connected to the DVR and that the power switch is in the "on" position. If the problem persists, you may need to replace the power cord or contact the manufacturer for assistance.
Lorex model LHV221600. Where can I obtain an owner's manual?
https://www.lorextechnology.com/downloads/security-dvr/LHV1000/LHV1000_SERIES_MANUAL_EN_R2.pdf
4answers
Lorex password
Should be1234 unless u have changed it
Does the lorex dvr support my MAC os on my pc
Hi Kavya,
Which model of Lorex DVR are you using? Currently, only some of our security DVRs are compatible with Mac OS X (via Safari). Our line of Edge and EDGE+ DVRs (LH300 Series) are Mac compatible and offer full remote viewing, playback, backup, and setup using Safari.
Please give us a call at 1-888-42-LOREX(56739) or visit us online at www.lorextechnology.com
Cheers, Lorex Support Team
I have 2 lorex dvr's. both need web access, can it be done
there are a few ways to accomplish this. one way is you will need more then one static ip. one static ip for each machine, you will then be hitting them on the same port but different ip's. the simplest way is to change the web port setting in the lorex dvr from 80 to something else in the second machine.
1helpful
2answers
Cant access lorex DVR from the internet
u need a public ip with an open port, and portforward the port with the ip of ur dvr
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
