If it was accidentally put in Demo mode, and you're not sure how you did it, how do you take it out of Demo mode on purpose?If it was accidentally put in Demo mode, and you're not sure how you did it, how do you take it out of Demo mode on purpose?
You can't post conmments that contain an email address.
Please follow the below mentioned procedure to disable Demo Mode in Acer Iconia Tablets.
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message. Note: Cust may see the "Demo mode" icon in the homescreen, however it wont bringup Demo Video
Regards
below is a link if you read #14 this will give you instructions on how to install the software that has removed it i have not registered so i can not confirm the software works.you will need to down load a file called SystemPack.APK and run it from your tablet as ypu would a app
The demo scree can be remove but, only by the retailer you got the device frpm. Unless it doesn't call for a password or the store is willing to disclose it to you.The Demo screen is intended for diplay in a retail store. It should have been diabled when sold. Contact the retailer that sold it to you.-good luck, Ned-
On your home screen tap the the app button,then tap the screen saver app. Tap Enable Screensaver to turn the screensaver mode on or off. Then remove the check to "service enable" check box.
Please try this:
