SOURCE: 1997 Chevrolet Z71 Pickup (intermittent start)
saved me the job of answering ,which would have been the same
SOURCE: blower motor not working 1994 jeep cherokee
Sounds like your blower motor rheostat needs to be replaced. I'm about to replace mine for the second time. Fan just quits working altogether when the rheostat goes.
SOURCE: 1994 Toyota Tercel Starter Problems
sounds to me that you have an igniton problem not a starter problem and or if you have or had an alarm system could be cause if u do give me feedback and i will explain but seems that your starter is fine from what u say but if you think in terms of the elemts to start a vehicle batery gives pwoer to ignition which sends to starter which gives spark etc i would check you ignition system something is causeing a short and not alowing starter to function
SOURCE: Purple solenoid wire shorted, no pwr coming from ign switch
look for a 5 amp fuse, crank fuse in car, not under hood
