A top load machine the noise we drive you up the wall squeaks only while it is in the wash rinse cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a squeaking noise during the wash rinse cycle on your Frigidaire washer. You could be hearing the noise from your motor during that operation, this is normal. Additionally, if you feel that this is noise an issue I would contact a professional to come out and diagnose your appliance properly. -Matt
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
SOURCE: LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
PROBLEM RESOLVED!!!
The best I could find by scouring the internet was that it was a communication problem between the central control unit and the electronic control box. I was getting F1 codes that would stop the wash, then diagnostics showed F68 and F41 codes.
Sears wanted to charge $65 just to come out and diagnose it themselves, and these appliance sites wanted to charge their own fees to offer solutions. So I took a chance and ordered a new electronic control box ($146.00 + S&H) and installed it myself.
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing, I lifted up the hood up and forward, and there was a black box - the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box - named by colors). No more error codes!
This washer is only a year and a half old as well, I guess it will pobably be my last Kenmore/Whirlp
SOURCE: Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
