In my house we had a power surge, since then it hasnt turned on, my dad checked the voltage, none comin from the power supply, and the fuse is good, any idea what it could be?
SAMSUNG BN44-00510A P51FW_CSM, PSPF351501A POWER SUPPLY https://www.abctay.com/wholesale-samsung-bn4400510a-p51fwcsm-pspf351501a-power-supply-p-857.html
I need the power supply number. BN44-00?????
SOURCE: power light comes on and clicking is heard but no
your problem is more a defective y board with y buffer boards one of them is short
SOURCE: Samsung HP-P4271 42 in. HDTV Plasma power problem.
Yes,this is the problems,might have bad plasma screen panel itself.Have a tv tech.to check it out.If the plasma screen panel it dead,tv not worth repairing.Plasma screen itself will cost the same as a new tv,if u able to buy it.
SOURCE: will a power supply for a 50" plasma TV work with a 42" plasma TV?
sir it will work with your TV..
SOURCE: How to troubleshoot Samsung plasma tv power supply
If relays are clicking, the problem could also be the diode connected to the relay or its own power supply. Check whether the relay is getting power enough to remain activated. This chattering can also be caused due to relays becoming weak or by short circuits on its load.
Here are some DIY steps that may help you fixing the
problem.
1. Check the power cord - check the cord it might be opened
(no continuity).
2. Check the internal fuse - sometimes the fuse fail because
of the power surge, replacing with new one will cure the problem, If this is
the case I've advice you to use surge protector/AVR (Automatic Voltage
Regulator). However if the fuse blew again this is an indication that you have
a shorted parts on the power supply, you may visit the link http://www.fixya.com/support/r8053361-fuse_keeps_blowing
for more info. If no reaction and still the unit didn't power up then you have
an open parts on the power supply.
3.If you see that the fuse is intact on the board, don't
attempt to touch anything because there some fatal components stored
electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified
technician because isolating the problem on the power supply is quite technical.
Also check if your unit is under warranty before opening the
back panel, it will void the warranty. Avail it because the manufacturer of
your unit will fix it for free or a little charge only.
Hope it may help you.
Thanks for using fixya.
JDVillanueva
