Sony TV XBR-43X800G solarized picture, how to fix
If you're seeing a solarized picture on your Sony TV XBR-43X800G, there are a few things that could be causing the issue. Here's how to fix it. First, check the input source.
If you're using an HDMI cable, try switching to a different input. If you're using a component cable, make sure it's securely connected to the TV.
If the input source isn't the issue, try resetting the TV. To do this, unplug the TV from the power outlet and then plug it back in. Once the TV is back on, go to the Settings menu and select Picture.
Scroll down to Picture Mode and select Standard. If you're still seeing a solarized picture, there may be an issue with the TV itself. In this case, you'll need to contact Sony customer support for assistance.
