Replace screen
SOURCE: samsung DLP keeps turning off
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Light Engine assemble problem
SOURCE: Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
SOURCE: Obtain repair manual for Samsung DLP projection TV's.
You can get the service manual by download link within minutes from the following link. Just scroll down the page and you will see your model listed.
http://www.tvrepairworld.com/service_manuals
Testimonial: "Your solution was very timely and helpful. Thanks"
SOURCE: have a 61" dlp samsung tv, making a humming sound
Bad Color Wheel.will cause this and it is a common problem for DLP Samsungs.
Part number is BP96-01103A
Samsung Parts 1-800-627-4368
SOURCE: I need to replace my digital board in my Samsung
You may not need a service manual to do this. I have a tip at http://www.fixya.com/support/r6981868-replace_circuit_board_in_modern_tvs which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
