Try to turn voice over off...only get blank screen
When voice over is on, you have to clic 3 times on round button to use it
infos Apple Canada Accessibility iOS Voiceover
General to accessibility. Then go down to Triple Click Home feature. Once you select Triple Click Home it will take you to the next page where you will need to select Toggle Voice Over. Now when you press the home key three times it will turn voice over on or off.
you have tu use 3 fingers to scroll in Voice Over
Triple click the home button. Then double tap the VoiceOver off button. This should allow the device to return to normal operation. Then you can reset by pressing and holding both buttons (power and home) until it resets if you need to.
SOURCE: iPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
