SOURCE: Power light flashing...TV won't turn on
Two flashes sugests that the power supply is faulty.It will have to be taken in to a service centre for repairs.
SOURCE: Audiovox LCD FPE3206 problems
Hi, All.
I ordered a new power supply module on ebay. Cost about 106.00 delivered. Came in a few days. I replaced the unit, bunch of screws, all wires were cable plugins, no problems at all.
After reassembly, it worked. What can I say? Sometimes ya just get lucky.
tom
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
SOURCE: Red power light and buzzing sound with red lamp light.
If the lamp does not light at all, it is probably a bad lamp. The buzzing may be the ballast trying to start the lamp or a problem with the power supply. Check the lamp and see if the arc tube is broken. If its a new lamp, you should be under warranty. I have the manual if you want to go to me site at allprojectorlamps.com. Just send you email to me attention Bulb Guy
