Drum may stop turning during cycle. manually turning drum will start rotation again
Videos here can help you more than all my words can.
whirlpool dryer belt slipping YouTube
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
SOURCE: Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
SOURCE: clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
SOURCE: When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
SOURCE: Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
