You are in somewhat of a fringe area and subject to the vagaries of proper reception. Hopefully you have a good outdoor antenna mounted as high up as possible. You might also consider adding an antenna amp to the downlead to boost up the signal.
Digital signals are not as strong or robust as analog ones and good reception can be thwarted by tree leaves in the path of the signal to your set!!!!!!!!! You should have as clear a line of sight to the transmitter as possible. Relocation of antenna is also another possibility.
SOURCE: TV doesn't receive signal
Faulty Video boards If you bought it in May then rapidly get it fixed under warranty or exchange it for a better brand. Who is Hannspree? not well known and may be cheap Korean TV with no parts available
Please rate our help to keep FREE service online++++Thanks for using FIXYA
