Manual latch for door opener also just broke
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
SOURCE: can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
SOURCE: ASKO w660 Parts
lick on this link and contact the parts warehouse they will be able to help you. http://www.askousa.com/buy-asko/contact-us/
