I've tried to open my flash disc but it says that I need to format it, I can't afford to do this because I'll lose valuable information that I have stored on it, how can this be resolved.
Also its seems to now have been renamed as ChipsBnk flash disk USB device, it didn't go by this name previously
I buy a new 4 GB Chipsbnk USB Flash drive.When Iplug into the compter,it says this USB is not formatted and ask me to format it. I click OK to format,but it can not format. What can I do to get it work?I buy a new 4 GB Chipsbnk USB Flash drive.When Iplug into the compter,it says this USB is not formatted and ask me to format it. I click OK to format,but it can not format. What can I do to get it work?
My Sony 8gig Pro Duo says it's not formatted when I hood it up to windows XP. But when I put it in my camera I can watch the videos I took. What to do?
I've tried to open my flash disc but it says that I need to format it, I can't afford to do this because I'll lose valuable information that I have stored on it, how can this be resolved. Also its seems to now have been renamed as ChipsBnk flash disk USB device, it didn't go by this name previouslyI've tried to open my flash disc but it says that I need to format it, I can't afford to do this because I'll lose valuable information that I have stored on it, how can this be resolved. Also its seems to now have been renamed as ChipsBnk flash disk USB device, it didn't go by this name previously
AnonymousJul 22, 2008
when flash drive connected gives error of not being able to open due to the media needing to be formattedwhen flash drive connected gives error of not being able to open due to the media needing to be formatted
The problem is that my removable disk can not open, when i try to open it, it says format the disk. I again tried to format it but i end up quiting the formating because it warned me that formating a disk will erase the data that stored in their and i was scared that i will lost all my data.The problem is that my removable disk can not open, when i try to open it, it says format the disk. I again tried to format it but i end up quiting the formating because it warned me that formating a disk will erase the data that stored in their and i was scared that i will lost all my data.
When I try to use my memory stick, the Computer tells me it's not formatted. I need the files onboard what can I do?When I try to use my memory stick, the Computer tells me it's not formatted. I need the files onboard what can I do?
I have the same problem.I tried to open my flash disk it says that i need to format it.I have the same problem.I tried to open my flash disk it says that i need to format it.
AnonymousNov 18, 2008
AnonymousNov 22, 2008
I have the same problem with the ChipsBnk flash disk also, it use to work, but now I can't access it or format it.
my LG 1GB flash has been buggin me ,as it insists on formatting and when i format it states that my windows xp is unable to...so how am i supposed to work on this flash disk?my LG 1GB flash has been buggin me ,as it insists on formatting and when i format it states that my windows xp is unable to...so how am i supposed to work on this flash disk?
AnonymousDec 25, 2008
try to read card, they ask me to format card
if we format all information will desapear?try to read card, they ask me to format card
i have valuable info on a usb drive and its asking for formattting but if i do this im gonna loose the info already stored please help as comp is so slow i need to get some stuff onto drive
AnonymousJan 21, 2009
help got all my information on this memory stick help got all my information on this memory stick
AnonymousFeb 22, 2009
I loaded my flash with information and there was no more space I tried to open the Flash disk and it was opening .When I tried to open it from another computer the reply is "Please insert the disk" yet the disk has alraedy been recognised. what can I do?
Ssuubi James
Ssuubi James
AnonymousMar 24, 2009
When I chose a document to open from my flash drive it says that I have to pick a place to open it from a huge list- what do i do?When I chose a document to open from my flash drive it says that I have to pick a place to open it from a huge list- what do i do?
I've tried to open my flash disc but it says that I need to format it, I can't afford to do this because I'll lose valuable information that I have stored on it, how can this be resolvedI've tried to open my flash disc but it says that I need to format it, I can't afford to do this because I'll lose valuable information that I have stored on it, how can this be resolved
You can't post conmments that contain an email address.
I can open my flash drive on any computer but not the one that im using. but i want the stuff that is on this computer to be on flash drive, i even tried to put it in my phone it ask me "the disk in drive E is not formatted do you wish to format" i even tried changing the drive letters.
I had the some issue as you , as I know in some manufacture they make a partition on the disk one for the system file of the flash and other for the drop down of the user file so might be by mistake you switched your flash to the first partition I mean to system file that is why you can not open that
Double Click on My Computer, then Right Click on the C: Local Drive and select the option to Format. Remember formatting erases everything so I hope you have an operating system disk to reload. Why format?? If your system is bad and you have an operating system disk, then when you reload from it you will get a newly formated disk. But again you'll lose all your docs, music, pictures and any programs you've added since you bought the computer.
<b>Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS<br />
<br />
<br />
Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for <a href="http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe">download here</a>. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (<a href="http://store.microsoft.com/Help/ISO-Tool">http://store.microsoft.com/Help/ISO-Tool</a>).<br />
<br />
or <br />
<br />
<br />
<span style="text-decoration: underline;">Please follow the steps below</span><br />
<br />
</b>
<b>Required:</b><br />
<ul>
<li>USB Flash Drive (4GB+)</li>
<li>Microsoft OS Disk (Vista / Windows 7)</li>
<li>A computer running Vista / Windows 7</li></ul>
<b>Step 1: Format the Drive<br />
</b>The steps here are to use the command line to format the disk properly using the <i>diskpart</i> utility. [Be warned: this will erase everything on your drive. Be careful.]<br />
<ol>
<li>Plug in your USB Flash Drive</li>
<li>Open a command prompt as administrator (Right click on Start >
All Programs > Accessories > Command Prompt and select "Run as
administrator"</li>
<li>Find the drive number of your USB Drive by typing the following into the Command Prompt window:<br />
<span>diskpart<br />
list disk</span><br />
The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.</li>
<li>Format the drive by typing the next instructions into the same
window. Replace the number "1" with the number of your disk below.<br />
<span>select disk 1<br />
clean<br />
create partition primary<br />
select partition 1<br />
active<br />
format fs=NTFS<br />
assign<br />
exit<br />
</span><span>When that is done you'll have a formatted USB flash drive ready to be made bootable.</span></li></ol>
<b>Step 2: Make the Drive Bootable <br />
</b>Next we'll use the <i>bootsect</i> utility that comes on the
Vista or Windows 7 disk to make the flash drive bootable. In the same
command window that you were using in Step 1:<br />
<ol>
<li>Insert your Windows Vista / 7 DVD into your drive.</li>
<li>Change directory to the DVD's boot directory where <i>bootsect</i> lives:<br />
<span>d:<br />
cd d:\boot</span></li>
<li>Use <i>bootsect</i> to set the USB as a bootable NTFS drive
prepared for a Vista/7 image. I'm assuming that your USB flash drive has
been labeled disk G:\ by the computer:<br />
<span>bootsect /nt60 g:</span></li>
<li>You can now close the command prompt window, we're done here.</li></ol>
<b>Step 3: Copy the installation DVD to the USB drive<br />
</b>The easiest way is to use Windows explorer to copy all of the
files on your DVD on to the formatted flash drive. After you've copied
all of the files the disk you are ready to go.<br />
<b>Step 4: Set your BIOS to boot from USB<br />
</b>This is where you're on your own since every computer is
different. Most BIOS's allow you to hit a key at boot and select a boot
option.<br />
<br />
This isn't a bios setting, it's a setting that Compaq put somewhere (probably the MBR) of your OS to only allow it's restore discs. If you want to use straight Windows XP OEM discs, just boot to the disc and you'll be able to install Windows. If that doesn't work, just format your hard drive(you'll lose everything) then boot to the XP and install that way.
I've been encountering this issue. The problem may come from the card reader or the card holder. If possible, use a different card holder and of problem persists, try a different card reader or test on another computer.
Try inserting it into a different USB port, or try one on a different computer. If that doesn't work, you'll have to resort to formatting the disk to continue using this flash drive. (Formatting deletes all the data on the disk though).
I noticed that too with my "VR" (and NOT "Video") formatted disks. I don't think you can finalize the VR ones. Instead you have to use the Sony Import tool to grab the videos. If you are like me you probably remember using the import tool with Video formatted disks BEFORE finalizing them and it takes forever to copy them. They must be finalized to view on other devices, copy using the import tool quicker, etc., but VR formatted disks seem optimized for importing (and can be edited on the camcorder directly.
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it. Required: ·USB Flash Drive (4GB+) ·Microsoft OS Disk (Vista / Windows 7) ·A computer running Vista / Windows 7 Step 1: Format the Drive The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.] Plug in your USB Flash Drive Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator” Find the drive number of your USB Drive by typing the following into the Command Prompt window: diskpart list disk The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1. Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below. select disk 1 clean create partition primary select partition 1 active format fs=NTFS assign exit When that is done you’ll have a formatted USB flash drive ready to be made bootable. Step 2: Make the Drive Bootable Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1: Insert your Windows Vista / 7 DVD into your drive. Change directory to the DVD’s boot directory where bootsect lives: d: cd d:\boot Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer: bootsect /nt60 g: You can now close the command prompt window, we’re done here. Step 3: Copy the installation DVD to the USB drive The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go. Step 4: Set your BIOS to boot from USB This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option. I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
hello, often the flash disc can't be opened or formated.
how to open ? is there any software for this problem?
thanks
These flash drives only work on Vista.
I can't read what is on the flash disk. this started after electricity cut
off can you help as soon as posible
I can't open my flash disk
My flash drive also won't open, keeps telling me to format my drive and then windows xp won't complete the format. Any ideas?
My flash when i try to open it ask me if i need to format it and i have some important document in that flash.Please how can i get it?
I am also experiencing de same problem. HELP ANY!
Ssuubi James
