Model av220c2, keeps freezing and throwing error code 2023 and wont feed paper through
Step to Fix Brother Scanner Error Code 2023:
-To handle this blunder, first, you have to kill your Brother printer and sit tight for like 15 seconds.
-Turn on the Brother Printer again and attempt to filter once more. -On the off chance that you are as yet unfit to check, evacuate all the power attachments and USB links from the printer and the PC.
-Check the USB ports completely. Supplant them in the event that they have to supplant.
-On the off chance that the USB ports are not harmed, reconnect them and attempt to filter once more.
-In the event that the Brother Scanner Error Code 2023 still repeats, uninstall the scanner driver and DSmobilecapture programming.
-From that point onward, you have to download and reinstall both the driver and the product.
-At last, attempt to examine once more. Ideally, your concern will be settled.
If facing any problem related to a printer please visit us Brother Scanner Error Code 2023
SOURCE: Paper Feed Problem
I had this same problem - you could hear the printer "trying" to pick the paper up. After a few cycles it would stop and pop up the media jam error. I noticed this would never happen when the try was half to completely full - only when the stack was low. I pulled put the paper, inserted a feather duster, applied some elbow grease (or wrist in this case) - problem solved.
SOURCE: PAPER WONT FEED IT KEEPS
I have a HP Photosmart A626. The paper won't feed. It seems like something is blocking it and sometimes takes me 5 minutes to get it in where at that point the paper is ruined.
Chris
SOURCE: hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
SOURCE: Error code 004-332 restart printer. Paper not
Check to see if your toner cаrtridges аre in the right position and locked in place. Then, stаrt the printer аgаin.
