Question about Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix wont turn on
Batt is fully charged
6ya staff
SOURCE:
Anonymous
  • 83 Answers
SOURCE: Re - Lumix Panasonic DE- 994 battery charger ??
Hi Cyril,
In theory this charger is fully automatic and stops the charging process once it detects that the battery has been fully charged (it will not restart charging until the battery has been taken out + put back in).
Of course, as with any electrical item, it's probably safest to unplug it if you're not planning to use it for a long time (e.g. weeks.)
Hope this helps.
Raf
Posted on Jul 06, 2009
Anonymous
  • 18 Answers
SOURCE: I have a lumix panasonic model DMC-LZ5 when it
This is a battery contact problem, the DMC's are horrible for it. Firstly as the previous answer said, take the battery out and clean the 3 copper tops (scrape them with a knife tip to remove ****) and secondly, make sure it is seating well into the battery cavity, you may want to pop a bit of tape on the back end of the battery so it is pushed in a little deeper by the door when it closes.
Posted on Jul 13, 2009
Anonymous
  • 691 Answers
SOURCE: hello! Our Panasonic Lumix will not turn on
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 29, 2009
Anonymous
SOURCE: panasonic Lumix
the same this is happening to me...three people have told me the lens mechanism is broken, or a software problem..that i need a total camera repair! an irritating "instruction" isn't it?!
Posted on Dec 06, 2009
Axel Gringmuth
  • 54 Answers
SOURCE: camera is locked open. battery is fully charged.
believe it or not, take your camera and wack it into your open hand, with the screen side. Remove first all rings on your hand or you might loose your screen. If this does not work your camera for all practical purposes is toast, too expensive to get repaired. Sell it on ebay with: "screen not craked" and buy a replacement: 230505313571. I also love this camera and they often come up on ebay for <$50.
Posted on Jul 30, 2010
Panasonic DMC FX01 with new battery still won't turn on?
If your panasonic camera uses a panasonic battery and you try to use a different brand equivalent battery, some panasonics will not work. Could that be your problem?
Nov 11, 2011 | Panasonic Lumix DMC-FX01 Digital Camera
Cannot turn on anymore my Panasonic TZ3
If the battery is fully charged then there is nothing to do but take/ send it in for service. Contact Panasonic or your retailer to find out where the closest Authorized service agent is.
Sep 15, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
My panasonic lumix ls80 digital camera turns itsel*** as soon as i turn it on
Be sure that your batteries are fully charged and in fact using name brand rechargeable batteries. If you are using Alkalaid, make sure they are fresh. Alks after a use that runs them down will come back after awhile for some more pictures. If you have fresh batteries and the camera turns itself off after turning it on, it probably has a problem in the power supply section or the switching section on/off on a circuit board.
May 20, 2010 | Panasonic Lumix DMC-LS80 Digital Camera
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Hi Cyril,
Hope this helps.
Raf
Jun 11, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
DMC Tz3 will not power up. Battery is fully charged. sometimes when it does come on it will not read card and will have to reset date and time.
First remove the SD card in case it is defective itself causing the camera to act funny. Next, your symptoms are indicative of a bad, not fully charged, or intermittent battery contact with camera's contacts.
Clean batt contacts using a clean pencil erasure.
If this doesn't work, measure a fully charged battery's voltage on the battery pos(+) and neg(-) terminals. It should be 4VDC. If less than 3.8, I would be suspicious it is not taking a full charge.
New batteries on ebay are cheap, and would not be a loss since you can always use backup batteries if you get another TZ camera. Or, you could just sell your camera to a repairman in an ebay auction, keeping your batteries and accessories, and buying a used working one with accessories cheap.
Feb 24, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Camera wont turn ON
hi lumix_user, these fuses are surface mount fuses and can not be changed by yourself, more damage will be done to the unit if you have no experience in the repairs department. take it from me i have seen what damage is done to units when they have been tampered with. please send to panasonic agents for repairs.
Jun 28, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
My camera wont turn on.
you might have gotten water in it or maybe your battery just isnt in fully
Jun 10, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
