Question about Dmm Vision Fitness T9500 Treadmill
Why won't the motor on the belt start? There is electricity and the elevation works.
There is electricity to treadmill. Elevation works, but motor will not start on belt. What could be the problem?
2 Suggested Answers
6ya staff
SOURCE:
fitnesspro
  • 9 Answers
SOURCE: I have a vision fitness T9450 treadmill. My wife
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Posted on Aug 05, 2010
How do I calibrate elevation grade for treadmill?
Hey there, sorry to hear you're having an issue with your elevation motor. I would be happy to help you solve the problem.
Since you already installed your motor you can go straight into diagnostic mode.
To get into Diagnostic Mode on your L8
Make sure to turn off your treadmill.
-ET's - Press Menu and Start at the same time
-CT's - Press Manual (or Display^) and Start at the same time
-All other L SERIES mills - Press Display (or display and Start at the same time
SideNote-
-*CT's that were manufactured after 09/2003 - Press Display and start at the same time.
Few things you want to do, if you haven't already.
A. Align the motor with the clevis mount and install the motor mounting pin.
B. Insert hitch pin.
C. Reconnect the elevation harness to the lower board
D. Set the lowest limit switch by holding the UP elevation button for 5 seconds. Then press and hold the DN elevation button one more time to make sure you only hear a click.
E. For L7/L8 machines; Thread the elevation nut to where its flush with the threads on the "worm' shaft.
F. Mount the elevation nut to the leg assembly by lining up the holes on the leg assembly. You may have to move the leg assembly so that the holes on the elevation nut line up. Then slide the two elevation pins through the elevation assembly and into the elevation nut. then secure the pins with the 2 set screws.
To calibrate your potentiometer you can try to adjust while it is installed but for best results you must calibrate it before its in your motor housing.
G. Calibrate the elevation potentiometer and to do so you must;
1st: Visually confirm treadmill is leveled. (0% grade)
2nd: Adjust the settings as follows;
All L SERIES millls should read 0.0
3rd: If the setting is incorrect, follow these steps.
Step 1: Turn the post of the potentiometer all the way
CLOCKWISE.
Step 2: SLOWLY turn the potentiometer COUNTER
CLOCKWISE until the setting is correct.
H. Carefully install potentiometer into the motor housing
*NOTE: The setting may vary when inserting the potentiometer
into the motor. As long as the change is minimal, fine
adjustment can be achieved by rotating the meter
while inside the elevation motor.
I. Press OFF to turn treadmill off. Then restart the machine in manual mode to TEST elevation after resetting your potentiometer. As long as the change is minimal, fine adjustment can be achieved by rotating the potentiometer while inside the elevation motor.
For more Diagnostic features and possibly further detail, I will be attaching a Link to your machines service manual. I hope this helps, always hear to help. SportSmith.
http://www.sportsmith.net/images/product_support/landice/Manuals/Service/P0472050%20L%20Series%20Service%20Manual.pdf
Apr 20, 2015 | Landice L8 LTD Cardio Trainer Treadmill
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
2)Alternative:
Jul 15, 2013 | Exercise & Fitness
Endurance xt3300
follow the steps and fix it. God bless you. You have 2 alternatives with this error.
2)Alternative:
Jun 19, 2013 | Exercise & Fitness
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
I have a Horizon QuantumCS 11 HRC Pacer Treadmill and I am getting E7 flashing when turned on,belt moves for seconds and then stops
please follow the steps and fix it. God bless you
2)Alternative:
Nov 15, 2012 | Exercise & Fitness
I HAVE POWERTREK STRIDER IS NOT WORKING WHAT WILL I DO
see the next causes and remedy and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 13, 2012 | Treadmill Doctor Nordictrack Powertread...
Squeek in motor of 6110p treadmill
Dear Sir:
The motor you can be oiled . But see the next instruction.
RUN THE SOFTWARE CALIBRATION FOR Easy diagnose and troubleshooting , see the instruction under the Hood of Motor, and follow the step or user manuals. Inspect the 1) Potentiometer + gear of the same Pot ( lubricate very slight).
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Schwinn Exercise & Fitness
I plugged it in and it will not start. It was working fine yesterday but now nothing.
Did it possibly blow a fuse in the treadmill? Also, Check your circuit breaker as well, and see if a circuit blew that was dedicated to the outlet.
Read the user manual of your treadmill to find the elevation motor. The treadmill fuses are located inside the elevation motor. If you don't have the manual, contact the manufacturer of the treadmill and ask if it can send you one or if there is one you can download online.
Turn off the treadmill and unplug it. If you have recently used it, let it cool down for one hour before opening.
Place the treadmill on its side and use a screwdriver to unscrew the lid off the elevation motor. Carefully remove the fuses. Some treadmills have easy access to internal parts where you don't need a screwdriver. If this is the case, simply lift the lid off.
Take the faulty fuses to a hardware store to make sure you purchase the correct replacement fuses.
Insert the new fuses into the elevation motor and close the lid. Plug in the treadmill to see if it works.
Sep 06, 2011 | Sears Exercise & Fitness
Dmm Vision Fitness T9500 Treadmill Logo
131 people viewed this question
Top Dmm Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
