Question about Michele CSX Watches
How to change day on Michele csx watch? - CSX Michele Watches
6ya staff
SOURCE:
Anonymous
SOURCE: I just bought my wife a michele csx-36 watch. Its brand
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Posted on Feb 28, 2010
Roipatrick
  • 906 Answers
SOURCE: Watches CSX Diamond: how do I change the battery...
good day,
hope this link below will solve your problem.
watches
Posted on Jul 30, 2010
sig78
SOURCE: The red bead (?) on the stem of my Michele CSX
I also chipped the enamel on the crown. You should take it to the place you purchased it and they will send it to Michele (actually Fossil) for repair. I had my Michele for 5 years before sending it in to have the crown repaired and have since lost the stem. Prior to that first repair, I did not have any issues with my watch. I really think that the parts used on my watch for the first repair were shotty. Very disappointing, but what do you do?
Posted on May 01, 2011
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: Had the battery replaced in
Loose cannon pinion or cannon driving wheel; the seconds hand represents the wheels in the back of the watch going around ok, but the power need to transfer through to the front of the watch somehow.
This is done by snapping/clicking two wheels together on either side of the main plate. The one on the dial side (cannon pinion) needs to slip to be able to set the time as the minute hand is set on this pinion. Im sorry, its time to see a repair guy.
Hope helps.
Posted on May 04, 2011
watchmacher
Michael
  • 302 Answers
SOURCE: MICHELE CSX HAND ALIGNMENT
You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
Posted on Oct 21, 2011
Am I able to buy 3 links for my Michele watch?
yes contact the manufacture / google it. call with model number.
Jan 31, 2012 | Michele CSX Diamond watch
I didn't wear my Michele CSX 36 w/ diamond watch for a few days..When I went to put it on the time was wrong. So I tried to correct it and now it has not kept accurate time w/in a 24 hr period. Fo
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement.
So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement.
So it should be nothing major and just a battery.
Jan 23, 2012 | Michele CSX Diamond watch
Oct 21, 2011 | Michele CSX Diamond watch
Can i remove links from a michele deco mini watch
Any watch repair shop will usually do it for free or under 5 dollars. You can do it yourself with care and very small set of screwdrivers which are probably about 10 to 20 dollars at any department store. I recommend a shop, and they can usually do that for you in less than 10 minutes
May 05, 2011 | Michele CSX Diamond watch
The red bead (?) on the stem of my Michele CSX watch came off and was lost.How do I get a replacement? Thank you. Patty
Apr 21, 2011 | Michele CSX Diamond watch
HOW DO I CHANGE THE DATE ON MY MICHELLE DECO WATCH
Turn the dial toward you and pull out. Then turn the dial away from you to change the date (you can only go upward in date).
Mar 09, 2011 | Michele CSX Diamond watch
good day,
watches
May 16, 2010 | Michele CSX Diamond watch
I just bought my wife a michele csx-36 watch. Its brand new. The watch runs for about one day then stops . What do you think it is. We did replace the battery already. Thanks
Dec 14, 2009 | Michele CSX Diamond watch
Watches Logo
Top Michele Watches Experts
Marvin
Marvin
NOEL
NOEL
fitzperfect
Level 1 Expert
Are you a Michele Watch Expert? Answer questions, earn points and help others
