http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More Recommended electric smoothtop ranges Electric smoothtop range Ratings
Electric induction ranges (9)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More Recommended electric induction ranges Electric induction range Ratings
Electric coil ranges (10)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More Recommended electric coil ranges Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More Recommended gas ranges Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More Recommended pro-style ranges Pro-style range Ratings
Tamppan Range/Stove/Oven Fault Codes Failure CodeConditionCheck/Repair
F0 & F1
EOC (Electronic Oven Control) failure
Replace Electronic Oven Control
F2
Oven too hot
Check Bake function, if OK, replace oven temperature sensor
F3
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
F4
Oven temperature sensor shorted
Replace oven temperature sensor
F5, 6, 7
F8
Lock switches
Check switches and replace if necessary
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
we had the same problem on our 10 yr old creda. gas man said new ffd required (flame failure device). he reckoned on around 80 pounds sterling for new part,even if it was still available, plus maybe 2 hours labour. we bought a new cooker!
i would look into the valve/regulater at which you connected the gas line, off to the side or somewhere on the regulater itself there should be a shut off for the oven control, simply flick to open positon and you should start right up. it would shut off gas to oven but allow burners to light.
