SOURCE: DMR E55 won't read RAM Discs
clean the laser lens do no use a lens cleaner disc you need to dismantle the drive unit and clean lens with cotton bud and a isoproplyn solution also clean the disc turnble and clamp if possible get it done by somebody who knows what they are doing
SOURCE: New Unit- Plays VHS - Records VHS - Plays C.D's - but ... ALL DVD's say
How old is your player?, has it ever played DVD's ?.
Try and avoid cleaning disc's.
SOURCE: Panasonic DMR-E55 DVD Recorder won't read most dvd-r brands
Hello jancinn,
This might be due to a dirty pickup or scan laser head, or the optics as a whole might be going bad (both are common problems). A qualified TV repair person should be able to determine if the scan laser or pickup head are bad by doing a laser power test. If the optical devices are dirty it is just a simple matter of cleaning them with a DVD cleaning disk, however if the optics are bad, then replacing them is actually cost inefficient, and you may want to think about getting a new DVD player/recorder.
I hope this helps,
Thank you,
Shuttle83
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
SOURCE: cannt play/record DVD's - keep
Depending on the formats of the discs you tried, and assuming they are the correct ones for this machine, it sounds very much like a defective DVD drive and/or software within the unit. If it is under warranty take it to an authorised service agent/workshop for assessment to see if it needs a new drive or not. If it isn't reading any discs, and the unit is brand new, it would most likely be the drive which would be at fault.
