My simpson esprit 500 stop working. It pumped water in but would drain at the same time. The result: a never ending waterfall. It would not spin or go thought the cycle. So someone gave me a esprit 450. It worked fine when empty but when I went to do a load, it did the waterfall thing again... Agggrrrr ! What is happening ???
SOURCE: Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
SOURCE: Fisher& Paykel fault 37 - on large loads water
the programer has given up the gost on you only thing you can do is try to replace it,,,
SOURCE: washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
SOURCE: Hi i have a zanussi
Okay .First you need to say if the pump is working or jammed if you have cleaned the filter then its possible the pump needs replaced......
