The washer had been working fine. Started a load and left it. Came back later to find it still full of water. Attempted to start a drain or spin cycle or anything - nothing happens. I spin the dial to various points, pull out the knob and nothing happens. Checked the plug and the fuse box - all good. What can I do?
Sounds like this could be a blocked/air-locked filter.
easy fix if so.
First. switch off the Machine at the socket.
Check your washing machine user manual for the location of the pump filter access screw. (Normally situated behind a front bottom clip out panel) ensure you have a few towels and a couple of pans/dishes at the ready before releasing the access screw, expect two or three litres of water to drain... as well as whatever is blocking the filter. (could just be an air blockage or a small object) replace the filter screw and clip off panel, switch on at mains.
Hope this helps.
Testimonial: "I do not have a user manual to find the location of the pump filter"
SOURCE: Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
For a detailed Washing Machine illustration, click below.
Top Load Maytag Style
Top Load Whirlpool Style
Top Load GE Style
Front Load Maytag Style
Front Load Frigidaire/GE/Kenmore Style
Warning!
To avoid personal injury or even death, always disconnect your
appliance from its power source--that is, unplug it or break the
connection at the circuit breaker or fuse box--before you do any
troubleshooting or repair work on your appliance. Also, because some
components may have sharp edges, use caution while working on your
appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
SOURCE: Kenmore Elite Model 970-C41074-00. Front Load
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
