I have a error code come up SC460 what can be causing this
SC 460 The problem may just be dirty separation components that a cleaning may resolve. The code refers to the following:
The status of the power pack is checked every 20 ms. This SC is issued
1. Replace the high-voltage supply cable.
High voltage power: Separation bias output error
if the EGB detects a short in the power pack 10 times at D(ac).
2. Replace the high-voltage power supply unit
3. Replace the IOB.
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
553 is:
second.
Defective PSU
Defective IOB
Defective EGB
These codes related to the fuser a designed to prevent a fire
I would recommend haveing a tech look at it
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
