I have downloaded the maintenance manual and followed the instructions for accessing the duplex unit. But the paper is jammed where it is not accessible.
No issues i share a informative links please visit and read it.
Read more help... How to fix printer paper jam andHP Printer Support
Thanks,
SOURCE: paper jam in Ricoh Aficio 1515MF
Go to this link, and click on "How to clear misfeed a,p,y"
http://www.ricoh.co.uk/KBase/KBLink.cfm?ProductUID=1878
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
SOURCE: paper jam leading to error code sc440-01
I think the code is a black pcu motor lock. Replacing the black pcu might fix it, but the black waste toner section could be backed up.
SOURCE: paper jam indication, but cannot find the paper that is jammed
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
SOURCE: Follow instructions in right cover to remove
open the right door right in front of your PCU are 2 long rolls a black and silver turn these by hand so the torn paper between them comes "up" -Carl
