Question about Maytag MER6872 Gemini Electric Kitchen Range
Bottom oven bottom element replaced but still not heating
I used the repair listed below. Thank you! Never fixed anything like this before but I did it! I soldered like it says and did it! You saved Thanksgiving!
As posted from Geoff Andrews -
“Just fixed my Maytag MER6772BAS my lower oven element was not working & buying a replacement element did not fix it, I found the problem in the control panel circuit board. The relay for the lower element had a bad solder connection to the board ( the yellow wire relay ) re-soldered connection & problem fixed. Check everything before shelling out hundreds on replacement parts. I had to take the control panel apart to fix this issue be carefulll not to force any of the connections, do not disconnect any of the tape wire harnesses. REMEMBER DISCONNECT THE POWER 220 VOLTS WILL HURT. ALOT.”
Posted on Nov 14, 2019
    Genius:
  • Maytag Master
  • 2,548 Answers
Replace the switch.
Posted on Aug 27, 2014
  • Dennis Ballow
    Dennis Ballow Aug 27, 2014
    There are 3 switches? Which one?
  • Richard Warren
    Richard Warren Aug 27, 2014
    There should be only one switch to turn the oven on .
6ya staff
SOURCE:
Geoff Andrews
SOURCE: Bottom Baking element not working
Posted on Oct 29, 2011
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: bottom element in oven not working
bake%20element2.jpg Bake element Most times it is easy to see a failed oven element. Their will bea hole or a welded mark somewhere on the element where a piece ofcheese fell on it and caused a hotspot. You can also check elementswith a meter or simply apply some wall current to them using a cheatercord to see if it gets warm. If the element gets warm that means itwill work and is not bad. If the element ain't coming on but you havechecked it out, of course then that would be the thermostat. HEADS UP: When fooling with the stove always be sure the power isoff. Pull out the bottom drawer and most of the time you can unplug thepower cord without moving the stove. To make it easier to work on most stoves the oven door can beremoved. I set the door at the broil position and gently ease up on thedoor, remove it, and set it to the side.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 22, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: Oven will not heat
Hello, your problem is going to be a bad igniter. you should replace it. Good luck! Mike
Posted on Nov 02, 2009
Anonymous
SOURCE: Baking Element Caught fire
funny same thing just happened to me and it all seams to be the bottom element of the same ovens around the same year, I bought mine in 99 also, I keep my oven very clean becasue i know the dangers it may cause, I think this is a major problem and it needs to be addressed.
Posted on Dec 11, 2009
thebabybigd
SOURCE: Maytag Gemini bottom oven not working
both ovens on my new stainless steel maytagmgr6775 not heating up.............
Posted on Dec 11, 2010
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Bottom oven bottom element doesn't heat
Phil. If you do not have voltage at the element, then the Electronic Oven Control ( EOC ) has failed. Part number # 5701M403-60
In order to check for the correct voltage at the element you will need to remove power and pull the range out of its installed location and remove the back panel of the range to gain access to the wiring and element. CAUTION ! I cannot stress this enough ! There are dangerous voltages in this area!! After the panel has been removed, return power to the range,set the lower oven to bake, and check the voltage at the element. You should find 220-240 volts between the element terminals with them connected to the element. If you do not have the proper voltage then you will need to replaced the EOC.
Apr 18, 2014 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore electric oven bottom element not working
check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
Jan 07, 2014 | Ovens
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Tappan Oven 316246653. Preheating the Oven does not work. Bottom Heating Coil (if thats what its called) is not working. The Broiler Coil at the Top does work. Is it the bottom coil that needs replaced...
Usually when the element fails to heat up, It means its usually broke, cracked, or where they plug in gets brittle and breaks. Your best bet is to replace the bottom element.
May 23, 2011 | Microwave Ovens
Oven's bottom heating element does not heat
this should show you how to change it
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
The main fault when the oven is not heating is that the element has blown here is a video on how to change your fan oven element and the motor.
For all your fan oven element click here
Jan 07, 2010 | Frigidaire Ovens
Bottom oven failed blew fuse when reset only bottom oven not working
It sounds as if your bottom oven heating element has 'blown'. You will need to replace the heating element.
Dec 26, 2009 | New World E90DOa Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
May 25, 2008 | GE JBP66 Electric Kitchen Range
Maytag MER6872 Gemini Electric Kitchen Range Logo
192 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Marvin
Marvin
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
