The pictures taken are showing horizontal lines on the images produced ?
SOURCE: too bright with lines too. My camera shoots too
it is a possible CCD FAILURE !
u are covered dont worry it is a
manufac fault inn CCD's ur camera manufacturer will do it Free of charge pls see the link
and call them and PLS RATE ME FIXYA for help
http://www.imaging-resource.com/badccds.html
dont worry if u are not on list just call them !
pls dont forget to rate me
SOURCE: Horizontal lines running through pictures
You no need to fix this problem. This is a CCD failure and in some cases had been subject to a recall.Contact Samsung support this may be one of the recalls and replacement camera could be on its way. They will do it for free of cost.
Thank you !!
SOURCE: the pictures have horizontal lines
This is electronic shutter problem that is the reason you get blinder effect/ noise on picture. Electronic shutter is located in lens mechanism and lens assembly will be replaced to solve the issue. Nearest Samsung service center or local camera repair shop will help you to replace lens assembly.
Thanks.
SOURCE: Samsung L830 digital camera Has horizontal
Possible that the LCD shows an excessive luminanace with a retrace and could be related to some errors in the LCD as there is no fault when the picture is seen after shooting.
best is to take a consensus before any tampering is done as it is best to check with screen before being replaced,Sometimes the errors can be in the control board.
