There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera. More detail, see here How to fix a ‘card locked’ problem
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Hope you are trying to do this after downloading the software you have got with the camera. Hope the memory card is not protected. You can check these once and try again.
I've seen this camera glitch up before when trying to delete a video from within the camera. I'd suggest connecting it to a computer and deleting the video off the memory that way.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
On PLAY mode, with a valid memory card inside, press MENU/SET, goto to COPY, select internal--> memory card, select YES, and then MENU/SET.
You better charge your battery before doing copy. Don't turn off the camera during copying.
Good luck.
Check to make sure the memory card is inserted the right way. Otherwise the camera will only read the memory that came with the camera, which is very small.
memory card locked Panasonic Lumix DMC-FS15
