HP Color LaserJet 5500 Printer Logo
A
Anonymous Posted on Aug 26, 2014
Hp 5500 dn laser replacement
Laser
George Mclaughlin
Level 2:
Sergeant:
  • HP Expert 372 Answers
  • Posted on Jun 10, 2016
George Mclaughlin
HP Expert
Level 2:
Sergeant:
Answers
372
Questions
Helped
128278
Points
839
It's not all that hard to do. You can also swap the lasers between colors to troubleshoot. Lasers come out from the rear of the machine.
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Dec 13, 2007
SOURCE: number of pages tracking on daily basis in hp1018 laser printer
try Printer Test page
The Printer Test page contains information about printer driver and port settings. The page also contains information about the printer name and model, computer name, and so on.
You can print the Printer Test page from the printer driver.
is it on the network? login to the printer using http://<ipaddress of printer>
other option is to contact hp support online.
Anonymous
  • Posted on Nov 05, 2008
SOURCE: driver hp laser jet 1020
hp driver 1020 downlord
Anonymous
  • 2306 Answers
  • Posted on Jul 09, 2009
SOURCE: hp laser 4000 keeps coming up w/ 41.5 error
41.5 is a paper feed error, take out the paper tray and clean the rubber roller above where the paper goes with a cloth just damp with water. Dirt on that roller will stop it from picking up the paper.
Anonymous
  • Posted on Jul 27, 2009
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Anonymous
  • 81 Answers
  • Posted on Oct 13, 2009
SOURCE: 81.0180 EIO 1 error code on a hp laserjet 5500 dn
The printer has encountered a problem with an EIO card device in slot 1. Power off, remove the device from the slot and power on. If it comes up ready then refit the card and try again. if it still fails with the error recommend replacing the EIO device in that slot
How do you replace the scanner cover oh the hp fax machine model 920
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
How to instill laser jet 2055 dn software
not sure ,how to "instill"
but if you want to install it , insert the cd , follow steps and once the software tells you to connect the printer then connect it , not before!
software should be available on any HP website
1helpful
Replacing laser assembly/mechanism on Denon DN-C635 CD player.
Don't usually have to do any alignment when replacing the pickup.
Received fuser error u4-1. Replaced fuser, and still get same error
Try to hard reset your printer. To do this, unplug the cord at the rear of the printer while still powered on. Then remove it the plug from the socket. Let it sit for a few minutes. Then, plug the power cord and then reattach the cord at the back. The printer should power on itself, if not just power it on manually by pressing the power button.
Doing the hard reset should clear off any error messages from your printer's memory.
HP 8100 dn error code of 57.5 comes up, power cycle down does not fix the problem
HP LASER PRINTER 8100, 8150 ERROR 57.5 code
1. The fan 1 or the laser/scanner fan has occurred.
2. Replace fan 1
3. Replace the D.C. controller board.
Try reseating the connector to the fan, it may have worked loose.
51.2Y error in hp 5500 color laser printer
Printer has a "laser" error. Could be bad laser/scanner assembly or DC Controller.
A printer tech is going to have to look at it.
Phaser 5500 will not duplex
its definitely a driver related issue.....download latest driver from www.xerox.com
22helpful
3answers
HP 5500 51.2M ERROR
Perform cold reset. How? http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl12227&prodTypeId=18972&prodSeriesId=25470&locale=en_US
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
k24674
Grand Canyon Tech
Grand Canyon Tech
