I do the general setup cleaning by pressing 7 then 6 then 3, after that my brother mfc-215c has a message of unable to print
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order.TIP: For the FAX models equipped with numerical keypads, you may press the Menu/Set, Black Start, and 0 keys instead in the same way as conventional models.Then "MAINTENANCE 10" appears on the LCD. Press 82 using the numerical keys/arrows.
Then press the Menu/Set key.
Error code will display indicating source of error if it is 41 thats print head error, not worth a cracker, replace machine.
press stop to exit if needed.
What is machine error 26?
What about 2A?
Fixya,,i think that is the one of your help
SOURCE: brother mfc-215c unable to clean?
The ink blotter in the bottom of the machine is full, this is a built-in redundancy. Machine needs to be completely stripped to replace this.
Buy another brand next time.
My printer said "unable to clean" I unplugged it and plugged back in. Now it says "maintenace 7". Tried "menu/set, *, 2,8,6,4 that didn't work. Tried "menu/set, black start" that didn't work either. Please help!!
DCP 330 C report that Unable to clean 51 message and it dosen't work
I have a similar problem with my Brother MFC 410CN which now displays the message 'unable to clean' & will no longer print, scan or copy. I followed the instructions posted on this site for getting the error code which displays as WSW00. Does anyone have any idea what this may refer to as this printer hasn't had much use & I would rather not dump it if it's on something trivial.
Thanks
I followed the instructions and am now getting "machine error 46". What is that?
printer wont clean says refer to maintence guie
I have followed suggested operations, but am only getting machine error 46...... any Ideas???? HELP!!!
I got problem on my printer mfc-215c ,it's show "unable to clean See troubleshotting......"
How can I do,,,,,, I already try to check follow the user guide,but noting happen?
peter
What is machine error 46?
What is Machine error 49?
what does maching error 4F mean
error 51
What is Machine error 51
brother printer saying unabel to clen dont have opt 7or 8 in setup menu
