This TV is a plasma according to the model number you've posted. It does not use a lamp.
If the plasma does not show any picture, there might be a defective Ysus, Zsus or power suppy board.
There is a high failure rate on the Ysus and Zsus boards.
Search for a Ysus and Zsus board on google and you should find them.
Good Luck.
You will find some more info in this link.
i checked the Y-board, conducted voltage check but all voltage are normal. 5V normal, Va 60V normal, Vs 184V normal. Sounds is ok, but the pictue is so dark, small spot pixels visible. Any idea, please help!
